TrailCarnage skid plates installed
These plates are tough! made from solid, reinforced steel, professional cuts and welds, just top notch art work.
I am very impressed with the design and the fitment.
i no longer have worries about my front diff, steering rack, tranny or t-case anymore, these plates cover all the essentials.
I have been to his shop and talked with Tom several times, his products are top-notch and his knowledge and expertise are outstanding.
Ya'll definitely need to jump on a set of these before you have to pay major damages after your next 4x4 trip. these will pay for themselves after one trip.
contact www.urdusa.com for your plates.
Originally posted by Herkengineer
How much did they run (If I may Ask?)
How long did the install take?
How heavy are they?
did you get them local? or did you have to pay shipping?
How heavy are they?
Originally posted by Bighead
UNDERDOG/TC Skid Plates (from Vendor Advertising section)
Re: TrailCarnage skid plates installed
Ryan,
I do hope you were being safe and using wheel blocks behind your back tires while your rig was up on those ramps...
A good friend of mine had his up on ramps just changing the oil, manual tranny popped out and e-brake was not down, almost killed him. Luckily his wife knew how to work a floor jack and was close by to hear him scream before he passed out.
Those plates look awesome! I'm not sure how much you need those down south, but they do look like they would drain pretty well.
A good friend of mine had his up on ramps just changing the oil, manual tranny popped out and e-brake was not down, almost killed him. Luckily his wife knew how to work a floor jack and was close by to hear him scream before he passed out.Those plates look awesome! I'm not sure how much you need those down south, but they do look like they would drain pretty well.
Originally posted by Roadrunner
Ryan,
How long did it take you to install the plates and were the mounting bolts supplied? Thanks.
Ryan,
the front plate uses stock bolts.
the rear plate attaches to the front with supplied bolts. it attaches to the frame with 1/2" M13 x 2.5" bolts and washers. you need to buy 5 bolts, 10 washers, 5 lock washers. (about $10)
the plates are heavy, so its a PITA to install. you definitely need a floor jack.
best way: attach two plates together. attach rear plate to frame loosely. attach front of front plate to frame loosely. attach the all the middle bolts loosely. make sure the plates are correctly in place. tighten all bolts.
it takes some muscle to align some of the holes but if you keep your bolts loose, light taps with a hammer works great.
approx 45 mins to install.
Originally posted by CTB
Do you have to remove them to change the oil?
It is very rare that I see work that I am truly impressed with (especially the welding on sliders
from all the rookies) but those skid plates are top notch hands down. Congrats to TC for making a truly perfect skid plate.
Richard
from all the rookies) but those skid plates are top notch hands down. Congrats to TC for making a truly perfect skid plate.Richard
Originally posted by weldpro
It is very rare that I see work that I am truly impressed with (especially the welding from all the rookies)
FS[GreatLakes]: Toyota collection part out
88sasturbotoy
Jan 30, 2026 01:57 PM
Jun 1, 2021 01:51 PM
BeMiceElf
Oct 10, 2015 09:40 PM
