Diff lock wiring...any help appreciated
I have posted a while back about this before, but did not get a definitive answer. I am almost finished, but need a little clarification before proceeding.
I have a 98' 4runner ltd. Bought it with the RR diff lock all set up. Long story, but I ended up having to buy another ECU and switch for the locker. Problem is, the switch and ECU are from a tacoma (has only one grey wire as opposed to a red/blue wire - for a 4runner). I need to match the wires from my new, Tacoma ECU, with the wires from my 4runner's locker's harness.
If ANYBODY, with an ECU for a 4runner can simply look at the wires connecting to their ecu, and read off, in order what color they are, I can simply look at the numbers and match the wires. I would greatly appreciate this.
Thanks in advance. Hope someone can give some help!
4runner ecu
green with orange stripe{spd} to speedo
green with yellow stripe {R} to rear diff. lock control sw
yellow with blue stripe {RLP} to dash light, abs ecu, rear diff lock detection sw
white with black stripe {GND} to ground
Light green with red stripe {M2}pin 2) to rear diff lock motor
Light green {M1}pin 3) to rear diff lock motor
light green with black stripe {REL2}pin6) to rear diff lock motor-free side of limit switch
Light green {REL1}pin 9) to rear diff lock motor- lock side of limit sw
black with yellow {IG} to power from 4wd circuit
blue with red {4wd} to 4wd ecu, ecu, L4 transfer position detection sw
jerusry
Oct 19, 2015 05:28 PM
scottyg486
Jul 19, 2015 05:34 PM
TokyoD23
Jul 12, 2015 06:01 AM
WTB[PacSoWest]: Looking for a electric locking differential motor/ actuator
AaronM
Jul 8, 2015 07:15 PM
