Rear door will not unlock
Ok so this may be an idiotic question but here goes. On a 92 runner, is the ignition key the same key for the rear door? I cannot open it from the inside or outside!! Also, the rear window will not roll down. All of the fuses are good. Switch maybe?
CS
CS
Yes your ignition key is the same for the rear door. Did you have it open and or apart before all this happened?
CS
The window has to be all the way down for the door to unlock... that being said... when u hit the switch to lower the window, do u hear anything? Click, hum, anything? If not, I'd 1st check the window switch itself... I've gone thru a couple... after a few years of coffee/soda/dirt and grime, the switch will not make contact, and cease to work...
Good luck
Good luck
for the rear window, crawl in the back, and take off the driverside panel in the rear (it's big, and quite the B#$@% if ya know what i mean...
theres a relay block in there, all i did was give mine a few love taps, made my rear window work perfect lol
idk about the door though...
You guys are going to love this. I sprayed a little lube into the key hole and it works perfectly. Got the idea somewhere online but don't remember where. Man what a cheap fix lol.
FS[GreatLakes]: Toyota collection part out
88sasturbotoy
Jan 30, 2026 01:57 PM
Jun 1, 2021 01:51 PM
Iceman4193
Jul 15, 2015 04:48 PM
icentropy
Jul 14, 2015 10:23 AM
