1993 4runner 3.0 will crank but when you give it gas it bogs down and then back fires
I Have a 1993 4 runner I just bought. I bought it not running. I replaced the fuel filter, fuel pump,(Last owner fried the fuel pump using a wire from battery to fuel pump) plugs cap and rotor. The truck isnt throwing a code and i don't know wha else to check. Converter is good also.. Thanks for any help!!!!!!!
No history except it was a one owner and the timeing belt was replaced about 20thousand miles ago. It set up without running for about a year. He replaced the fuel pump but it would not run so he ran a hot wire to it to get it to crank but that burnt up the fuel pump. I replaced several fuses a 2 relays fuel filter and the fuel pump. Cranks rite up and idols fine but it loads up when u give it gas.
I have checked the vacuume lines havent been able to find one leaking but who knows I am at a stand still, I don't know what else to do. Guess I will just have to put it in the shop.
test the afm or tps u can find the way to test them in the fsm and that can be found here... http://www.ncttora.com/fsm/index.html
