22re clutch assistance needed
87 4runner with 22re and w56. I've checked my fsm for slave cylinder travel specs and can find nothing.
Here's the problem, clutch won't disengage fully when pedal to floor. Slave was replaced last year, clutch has maybe 60,000kms on it. Before I go replacing clutch master or clutch and pressure plate I'd like to verify I'm getting full travel at the piston (release lever to be precise)
Anyone know what that travel should be?
There is a bleeder valve on the slave. Put your thumb on it and loosen it, have someone press the pedal, if there isn't a hefty amount of pressure, if it doesn't push buy your thumb pretty easy, your master is bad. If it seems good, take your slave off and inspect it, if that's good, pull tyranny and inspect.
Just so you know, free travel on a hydraulic clutch can be a mis-nomer. Check the rod free travel at the master cylinder. You have to crawl under the dash to see it. This is where the rod coming off the pedal linkage hits the cylinder piston. Basically, you want it where there is JUST clearance. As in almost touching, but not quite. Think of a lever, a little clearance at the rod means a lot more clearance at the pedal.
John
John
voiddweller
19
May 2, 2016 09:10 PM
