Does anyone have a driveshaft grease diagrahm?
Old Apr 9, 2011 | 06:48 PM
burton6509's Avatar
It for a 2002 im confused on what kind of grease and where the locaion are at
Thanks
Old Apr 9, 2011 | 06:52 PM
MudHippy's Avatar
Kind = NLGI #2 GC-LB
Where = all the zerks
Enjoy!
Old Apr 9, 2011 | 06:58 PM
vital22re's Avatar
totally a bro
You will have to crawl around and look. There will be little nipples on the u joints. These may be a little difficult to get to so you may need to move the runner back or forth.
Old Apr 9, 2011 | 07:24 PM
burton6509's Avatar
Enjoy!
Do I use that on all the fitting... I remeber hearing about using some kind of molly somthing grease on certain fitting
Old Apr 9, 2011 | 08:07 PM
TheDurk's Avatar
Courtesyof Ih8mud:
TSB: Propeller Shaft Grease Types and Locations
Old Apr 10, 2011 | 06:52 AM
Rock Slide's Avatar
Any yet another write up - http://www.4runners.org/writeups/zerk/index.html
I just use valvoline synthetic grease on all the zerks.
Old Apr 10, 2011 | 09:35 AM
MudHippy's Avatar
Moly grease is a type of EP(Extreme Pressure) grease.
There are two popular opinions...
A. Use a type of grease that is specific to the application. Use EP grease where it's needed, namely friction bearings. Use non-EP grease where it isn't, namely anti-friction bearings. Use high-temp grease where it's needed, namely disc brake wheel bearings. Use mild duty, mild to moderate duty, or mild to severe duty rated greases as needed.
B. Use a high-temp, mild to severe duty, MP(Multi-Purpose) EP grease that's suitable for use anywhere. All mild to severe duty, EP or non-EP applications, including those with high operating temperatures. Such as greases that are graded GC-LB.
G = Wheel Bearing
C = Mild to Severe Duty
L = Chassis and U-Joint
B = Mild to Severe Duty
I use this stuff on everything, because it's top tier GC-LB(and it's cheap).
justdifferentials
Just Differentials
Jun 13, 2022 07:40 PM
kawazx636
Oct 6, 2021 03:03 PM
ladybugRC
458
Aug 21, 2020 10:41 AM
ToyotaMD
Aug 17, 2018 10:16 PM
