Toytech 3" Spacer Lift Kit????
Ok, You all know that the lift kit mentioned in the title comes with spacers for thr front struts and with longer coils in the rear to achieve a combined 3" lift. BTW I installed one of this on my 1997 4Runner SR5 2WD. With the kit installed my truck looks like it seats a bit higher than the front. Is this a known issue with this types of kits? I kept the factory front coils. Could this be the cause? Also toytech sales a thin spacer that is used to correct the driver's side front height. Does anybody had the same problem?
Here is a picture of my truck, although this pic barely shows the difference in height front to back:
Front lower is the normal rake of the vehicles stock suspension.
I've installed dozens of these lifts and never had to balance out one left/right with a trim packer.
If it's off that way the better option would be new coilivers up front as your front coils/shocks are worn out.
:wabbit2:
:wabbit2:
I have a question about this system, i recently replaced my front struts with bilstein hd's because they originals were worn out and i need to also replace my rear's but i want to get the toytec 3" kit that comes with the spacers in the front and the longer coil springs in the rear, my question is do i need to buy longer rear struts or will the factory length bilstein hds work? Since i have to buy new rear struts anyway i just need to know which length?? Any help would be apreciated.
Hope that helped.
http://www.toyteclifts.com/index.php...mart&Itemid=72
If you have any further questions feel free to give us a call. My extension is 107.
Thanks,
Jeff
Sep 4, 2015 09:27 AM
coffey50
Jul 28, 2015 10:55 AM
kirkrunner
Jul 27, 2015 07:59 PM
