Sponsored by: CARiD
Loud shhhshhh noise in air intake
Old Mar 11, 2011 | 03:21 PM
toyota hunter 07's Avatar
94 3.0 runs fine but getting a loud shhshhshh noise from air intake ...checked and cleaned kn filter pulled top off and hear noise like an obstruction ....buT when you hit the gas it goes away ...only at idle.....SOUNDS LIKE ITS SUCKING OR STARVING FOR AIR>>.
Last edited by toyota hunter 07; Mar 11, 2011 at 03:35 PM. Reason: MORE INFO ABOUT PROBLEM
Old Mar 11, 2011 | 04:31 PM
BeMiceElf's Avatar
Mine does the same thing. I have a k&n also.
Old Mar 11, 2011 | 04:54 PM
GranVille-4crawler's Avatar
do you have an intake or factory airbox?
Old Mar 12, 2011 | 04:51 AM
Factory air box with a kn .....but even after you remove the air box cover and filter ..you still hear it....looked up in there and that little metal air door is barely open...and if i open it with my finger a bit the truck stalls.....its loud and doesn't seem right....something with the mass air sensor ??
Old Mar 12, 2011 | 06:30 AM
250000_yota's Avatar
I'd bet good money the intake tube is split. Its a common problem on the 3.0. Check where all of the hose clamps connect the system together.
Old Mar 12, 2011 | 06:53 AM
hum............at work now but when i get home ill tear it all apart and check it out...
RatOmeter
Oct 22, 2015 03:17 PM
terminator
Jul 27, 2015 07:13 PM
calderp
Jul 27, 2015 09:58 AM
PlayAwhile
Jul 20, 2015 11:36 AM
kvanzandt1
Jul 18, 2015 10:15 AM
