newbie steering and lift Questions
1. alignment shop said my pitman arm and idler arm on my 94 reg cab 4cyl 4x4 was wore out so i needing to purchase these parts wanting something beefier then stock any sugestions ?
2. are sordi 1.5" ball joint spacers a good route to go ?
3. whats a few options for lifting the rear 2-2.5"
THANKS IN ADVANCE
THANKS IN ADVANCE
Pitman arms are solid chunks of metal and don't wear out typically. You're idler arm is a commonly known wear item. Numerous threads on beefy idler arm upgrades.
Bj spacers and a rear aal or block.
http://www.wabfab.org/IFS-Lift-Kits/...-products.html
:wabbit2:
:wabbit2:
wabbit the pitman arm on the IFS trucks have a rod end on them they do wear out.
Your thinking of the crossover steering on a SFA/SAS pitman.
If your gonna get a new idler arm stay away from the moog arm, get the FA5040 from autozone. IMO just as good as stock if not better. Only true upgrade to the idler arm is total chaos idler. Or an idler arm brace, but they only fit the FA5040 arms.
ups just delivered my Idler arm in the Mcquary-norris FA-5040 box. Well took it out of the box and the arm has a casting of 555 on the arm . Did i get screwed cause i assume this is a senki 555 put in the fa-5040 box ? dont know how to post pics but its bare metal not black like i see that the fa5040's are .
Sep 4, 2015 09:27 AM
coffey50
Jul 28, 2015 10:55 AM
