Interesting info about the K&N dropin A/F and others
http://22reperformance.com/22RE%20Pe...%20filter.html
Just read up on this. never thought about this. My throttle body was about that dirty when I rebuild my motor.
the black buildup has nothing to do with aftermarket filters...
search the forums for "black goo"
it's caused by the way the EGR system dumps out by the throttle body inside the 22re's upper plentum. it get's really bad like that if say an O2 sensor goes out and the engine runs really rich. a bunch of miles and blow-by can cause it to build up like that too
been there, done that, with a motor that had 260k miles on it and had been running an OEM paper filter for all those miles
K&N Filters are perfectly fine, but when you apply the filter oil, wipe it off with a shop rag so that is not dripping with oil. In OBDII cars, excess filter oil will cover the MAF sensor and cause a CEL code, system lean PO171 or the sort.
You're throttle body was that dirty because it most likely never saw a good day in its life.
Yeah guys, you don't saturate the foam filter in oil.
Lightly spray it on the outside, like a light dusting, then wrap it in paper towels to absorb some of the oil..
If this was the reason your TB was filthy, then all dirtbikes and fourwheelers in america would be this bad.. And they arent.
justdifferentials
Just Differentials
Jun 13, 2022 07:40 PM
runnermedic
13
Sep 21, 2015 05:20 PM
dropzone
Sep 13, 2015 11:18 AM
icentropy
Sep 10, 2015 05:03 AM
