85 smokes real bad until it's warmed up "really warm"
New head, new timing chain, all new gaskets, it smokes real bad until it's really warmed up then it won't smoke. Just wondering what it might be?
Visible white smoke when your engine is cold is normal since the cold exhaust is a saturated mixture. It isn't until the engine warms up that our exhaust gases becomes transparent (no longer visible) thanks to superheated vapor properties.
Can you be absolutely positive if you see any blueness to your exhaust or not?
Thanks
Mike
Thanks
Mike
If you don't see any blueness in the steam, then it is perfectly normal.
What I'd advise is to check your engine oil once a week for about a month just to make sure everything is normal.
It's more than likely we are overreacting and everything is just fine with your engine
But it never hurts to make sure everything is okay
BigMike
BigMike
Mine does this too. But mine is carb'd is yours? It's perfectly normal for the smoke to get a little darker (grey or blackish) when trying to drive a carb'd truck that hasn't fully warmed up yet as the choke has not had enough time to fully open, thus running a little richer.
Here are some examples of normal morning white smoke I found on Google:
The rear main is not related to your exhaust smoke. It is an involved job to change the rear main seal. You'll have to remove your transmission/transfer case, clutch & flywheel just to even see the seal. Then you'll have to drop the oil pan, remove the rear oil seal retainer (seal housing), and then replace the seal. Then put everything back together!
It is possible that your transmission input seal is leaking. Be sure to check if you are loosing motor or transmission oil?
If you do this, please please please please only use genuine Toyota seal and gaskets!! For something as difficult to service as this, NEVER settle for non-OEM seals/gaskets.
Also, it is possible to extract the seal without removing the seal housing (so you also don't have to drop the oil pan), but you must be extremely careful when installing the new seal that you install it perfectly parallel and at the proper depth. It is MUCH safer to replace the seal with the entire seal housing removed, and I highly recommend this, but it is more work. One way to view all the work is do it right with Toyota parts, and you'll never have to replace it ever again.
Here is a diagram from a 1985 22R engine. Notice the rear oil seal and it's retainer at the upper right:
Good luck!
BigMike
Good luck!
BigMike
sojourner567
Jul 16, 2015 08:52 PM
Kluch8651
Jul 9, 2015 10:39 AM
