Idle spped issue
Old Dec 19, 2003 | 02:55 PM
markjs's Avatar
Idle spped issue
My 81 22R will idle high when it is cold, but it will idle high for far too long. I removed the air cleaner while it was idling so high and tried to open the choke places and or unstick anything that seemed stuck but it continued to idle high for a maddening length of time and I found no moving part that changed the idle....Eventually a swift pump of the accellerator slowed the idle back down but it took way too long and the engine was way warmer than it needed to be. I read in a manual at the library that there is no possible idle adjustment in the 81 model. Is there a simple choke adjustment that will fix this problem?
Old Dec 19, 2003 | 03:01 PM
amusement's Avatar
Sounds like the choke needs to be replaced.
An electronic choke is inexpensive and will
resolve the issue of high idle too long.
EDIT:
There is a kick down circuit that is linked to the throttle cable cam.
The cam has a screw that can be moved back and forth to adjust idle.
Follow the throttle cable into the carb and you will see the cam, the kick down circuit, and idle adjustment screw.
Old Dec 19, 2003 | 04:11 PM
markjs's Avatar
So I porbably need the shop maual for the procedure?
Old Dec 20, 2003 | 01:32 PM
Maverick's Avatar
Check the voltage meter on the idle control sensor, and don't forget to check the main computer for any error codes. I had the same problem and I found that the sensor was bad; probably cost me 150 bones but will fix the idleing.
M
Old Dec 20, 2003 | 05:06 PM
amusement's Avatar
Maverick the 81 22R is a non-computerized carberator setup.
No throtle sensor either.
Old Dec 20, 2003 | 11:39 PM
markjs's Avatar
Here's the deal.....I can't get the choke replaced without buying a $50 carb rebuild kit. So is ther any cheaper fix to this problem which is at worst annoying?
Old Dec 21, 2003 | 08:22 AM
amusement's Avatar
If the choke is a mechanical type then it will be necessary to by the rebuild kit. However, there is always the junk yard .
I might same the same for electronic chokes. Try some carberator cleaner.
Old Jan 1, 2004 | 07:41 PM
markjs's Avatar
Not 100% sure yet but I found a linkage on the choke side that was unhooked and since I recconnected it there has been no further problem so far.
Old Jan 3, 2004 | 01:32 AM
markjs's Avatar
Well I am sure now....All just a stuck disconnected linkage.
Sleaker
Aug 26, 2020 06:03 AM
montanatruck
Feb 26, 2017 07:07 AM
Alex Bessinger
Aug 31, 2015 09:17 AM
greenbuggy
3.4 Swaps
Jul 23, 2015 11:51 AM
kyletbert
Jul 17, 2015 11:39 AM
