question about gears and a locker
Old Dec 18, 2003 | 04:52 PM
mtnkid85's Avatar
Im planning on putting a arb in my yota, but I was wondering if I put the locker in right now will I be able to change to 5.29 gears down the road with out doing anything to the arb? Thanx
Old Dec 18, 2003 | 05:23 PM
WATRD's Avatar
Your question is a bit unclear, yes you will have "do something" to the ARB in that you will have to remove it, then reinstall it to take out the old gears and set up the new gears, but no in the respect that on Toyota vehicles, you do not need a different part number air-locker for different gear ratios like some rigs. That is unless you are talking about an FJ40 which has two different part numbers depending upon what gear ratio you go with...
It's unclear what vehicle you are talking about and what "do anything" means to you...
Old Dec 18, 2003 | 05:27 PM
Cebby's Avatar
85 Runner
Old Dec 18, 2003 | 05:30 PM
44Runner's Avatar
it would be better to regear now so you don't have to pay to have them installed twice...
Old Dec 18, 2003 | 05:34 PM
WATRD's Avatar
Thanks... I saw that once I went and looked at the profile...
ARB only lists a rear application for that rig,
1984-88 4Runner 4Cyl 45mm carrier bearing RD01
For all gear sets.
Old Dec 18, 2003 | 05:47 PM
Cebby's Avatar
Thats surprising...
Does that mean that everyone with dual ARB'd 85's have swapped in a different 3rd?
Old Dec 18, 2003 | 05:51 PM
WATRD's Avatar
Originally posted by Cebby
Thats surprising...
Or they came up with one that worked or I am reading the chart wrong, or... heheeh
http://www.arbusa.com/alac/215110.pdf
Heck if I know
Old Dec 18, 2003 | 05:52 PM
WATRD's Avatar
Nope it's me... I read the chart wrong... the front is either an RD01 or an RD90, the same one the Tacoma uses... Depending upon the size of the ring gear and IFS or SA. I guess in this case it would be SA, so that would make the front locker the same as the rear.
But, either way, it's still not dependant upon the gear set
Old Dec 18, 2003 | 06:01 PM
mtnkid85's Avatar
hey thanx alot guys I appreciate it
Jun 1, 2021 01:51 PM
oldirtydirt
Feb 23, 2020 09:30 AM
jerusry
Oct 19, 2015 05:28 PM
Daneums
Aug 20, 2015 05:36 AM
A2theK
Jul 12, 2015 10:46 AM
