1992 Toyota Dually(automatic) question
I have to tow a 92 dually tomorrow and am wondering if I have to remove driveshaft. Does anyone have specs? what wrench/sockets I will need?
also could I not put it in neutral and leave it running?
Any help is greatly appreciated.
Thanks
Thanks
If the rear wheels are going to be on the ground then yes, you will have to remove the rear shaft. Unless your only going a short distance, 10 miles or less. I would say.
Even if you leave it running with it in neutral, it will cause damage, the rear shaft wont be getting lubrication while it spins with it in neutral, causing heat damage
GreenLion
Jun 7, 2021 10:49 AM
WTB[WestCanada]: 1992 4Runner Dash Cluster/Odometer
irish_tyrant
Jul 6, 2015 11:22 AM
TheManOutside
Jun 18, 2015 03:32 PM
