crane cam for 22re, should i buy it?
Old Jan 12, 2011 | 03:03 PM
85gijunk4x4's Avatar
i found a crane cam (272) mid range performance camshaft for a 22re on craigslist, for $40. anybody think this is a good deal? ive never heard of a crane cam, so i was wondering if its some kind of pos knockoff.
anyway, if you guys were me, would you say deal, or no deal?
thanks
Old Jan 12, 2011 | 03:04 PM
xxxtreme22r's Avatar
make sure it works with stock valve springs and you might not like the way it idles.
it's one of these 3 cams: http://www.summitracing.com/search/B...word=crane+cam actually skip the one in the middle.
Valve Springs Required Yes Yes that tell me your gonna need special valve spring to run that cam.
Old Jan 12, 2011 | 03:06 PM
how could i find out??
and does it idle different?
Old Jan 12, 2011 | 03:09 PM
flg8r22's Avatar
crane cams have been around a-looong time
Old Jan 12, 2011 | 03:10 PM
searching google now for more info on the cam
Old Jan 12, 2011 | 03:11 PM
hmmm. $40, for a $120 dollar camshaft. sounds like a good deal, thx xxxtreme.
Old Jan 12, 2011 | 03:12 PM
so after reading that, im guessing you can install it with stock springs and rockers,and all that
Old Jan 12, 2011 | 03:13 PM
Valve Springs Required Yes Yes nope.
Old Jan 12, 2011 | 03:15 PM
3 questions.
does it idle/run different??
is it just a bolt on, or do i need to adjust timing etc.??
does it work with all the stock components??
thanks for all the help
Old Jan 12, 2011 | 03:17 PM
no you need valve springs, yes it will idle funny (lope). Technically with the need for different valve springs it does not just bolt in.
Old Jan 12, 2011 | 03:35 PM
ehhh...alright then, not interested...
truck runs fine the way it is, -$40+loping idle=no deal.
thanks for the info man
Old Jan 12, 2011 | 03:54 PM
it would idle similar to this
http://www.youtube.com/watch?v=w9LExSLDV7g
Old Jan 12, 2011 | 04:00 PM
peow130's Avatar
It's not gonna have a lopey idle like a 350 with a cam in it..
It's going to idle like a rough-running 4 cylinder, that isnt running rough.
Old Jan 12, 2011 | 04:13 PM
2DoorRunner's Avatar
Sounds like a tractor lol
Old Jan 12, 2011 | 04:23 PM
haha yeah I don't like the sound of a high duration cam on a 22r either. Not to mention it kills your low end power.
Old Jan 12, 2011 | 04:25 PM
Sleepr71's Avatar
WOW..that sounds like...an 8N Ford tractor,or me after eatin a big bowl of chile.I wouldn't do a cam with that much duration in a (probably) stock comp. 22RE. It may sound/run o.k. with >10.5:1 comp., not a stocker otherwise..I say leave the cam alone (stock).Sleepr71.
Old Jan 13, 2011 | 12:10 AM
wyoming9's Avatar
Red face
You never said was this a new or used cam??
Even with a new Cam I would make sure you have an iron clad money back return policy
Being able to measure the cam also helps
Old Jan 13, 2011 | 01:43 PM
its a new cam, i wouldnt waste my time with a used one...
im kinda stuck on the fence now....
so what exactly are the pros and cons to this crane cam?
so far ive heard it kills your low end power
anyone else have any input?
Old Jan 13, 2011 | 01:55 PM
camo31_10.50's Avatar
it's just like the 270 cam from EB just a lil more duration..
will open up your top end a little bit...would be best paired with a free flowing exhaust.
i love the idle lope
Old Jan 13, 2011 | 01:59 PM
94toyota's Avatar
it all depend on the duration and lift of your cam some lose low end some gain more low end it all depends waht youdo with your truck there are almost as many cams for a 22r as there is for a sbc just do a little googling
