22re temp gauge not working when t-stat removed
Why would the temp gauge stop working when the t-stat is removed? T-stats aren't wired in. Afaik there is no sensor in a t-stat. anythoughts? Could removing your t-stat cause a head gasket failure?
Running cooler will also cause no heat from the heater, a clogged cat from the truck running richer trying to get the engine to heat up, and increase in fuel consumption.
Running with no t-stat in the summer really isn't an issue because your engine warms up much quicker in warmer weather.
In the winter, it takes much longer to get warm (if at all) without a T-stat. Very annoying seeing as you don't get any heat out of the cabin climate control.
I found out that my t-stat had sucked it's o-ring through itself cause my engine to be basically wide out t-stat all the time. I had to put a piece of cardboard in front of my rad so I could get some heat in my cab. Your engine will not warm up in cold weather without a t-stat or cardboard in front of the rad.
If you ever use/want heat in your cab, install a t-stat. They are cheap and easy to install. Two bolts and a little coolant and you're set to go.
the1998sr5
Oct 19, 2016 12:48 PM
B. Graves
Jul 3, 2015 04:10 AM
Eagle564
Jun 23, 2015 11:29 PM
