Oil Leak take a look.
I notice something was up when I saw this.
Then I looked and saw this. I thought it was coming from the seal on the crank shaft inside the oil pump but I guess not.
It looks like it's coming from the water pump?? Why would oil leak from these? Is the seal bad?
What do you guys think??
After looking at it a second time. Could it be that the oil pump seal is bad and it's slinging oil on the water pump and other stuff?
Front main seal or o ring seal in oil pump.
Like camo said, the spinning of the motor, belts etc. makes it look like it's coming from some mystery spot. In the photo you posted of the underbelly of the oil pump you can clearly see where fresh oil has made a trail down to the pan.
I would clean everything and then take a look.
If it is the front seal I would make sure to check the pulley where the seal is and see if there is a visible groove worn into it. If so you need to sleeve it and get an seal from the dealer.
Thanks dudes. Toyo are you talking about grooves worn into the crank shaft or the seal? Also I just replaced the front end with the engine builder kit. I'm hoping it's something with the oil pump seals.
On the 20 and 22r this is a common problem only because they are older and have seen more wear.
yes sir This link to 4crawlers site will explain the starter motor method.
http://www.4crawler.com/4x4/CheapTri...ingChain.shtml
Have not actually used this method my self because I had the engine out of the vehicle when I had to do it.
I have an Oil leak issue as well I think it's the oil pan gasket but it might be something else as well. I took some pictures...I can't get my oil pan off though due to it being STUCK because of the old gasket...it's pretty tight on there...
I was also wondering if bolts like this are common for the oil pan. There are two but one decided to just let the nut come out and the threaded piece stay in place...thinking of replacing it...with something easier to use.
That's not a bolt. It's a stud with a nut on it. And yes, they're there for a reason. They put one in the middle on each side to help keep the pan aligned, and held in place by the nuts, while you put the bolts in. It's alot easier to hold the pan up and loosely thread those nuts on, than having to put a couple of bolts in to hold it there instead. I'd suggest you leave them as the were.
On the stuck gasket, use a paint scraper or a putty knife.
That's not a bolt. It's a stud with a nut on it. And yes, they're there for a reason. They put one on each side to help keep the pan aligned, and held in place by the nuts, while you put the bolts in. It's alot easier to hold the pan up and loosly thread those nuts on, than having to put a couple of bolts in to hold it there instead. I'd suggest you leave them as the were.
No luck atm with the oil pan.
Probably go at it tomorrow some time since I have class tomorrow and need to do some work. I'm installing sway away torsion bars as well if anyone knows where I should start on those. I am not a mechanic and well I've only taken AT101. Little to no knowledge about cars in general.
hey buddy i had a similar oil situation with my 22re where it looked like it was leaking over by the water pump/alternator area. It ended up being the valve cover gasket. I would also check by the distributor where it slides in to the head and the area where the timing cover meets the head.
What was happening was there was a tiny trickle of oil that would run down all those brackets holding the ps pump and on to the alternator. it eventually took a toll on the alt and i had to replace that too. clean everything up real good and stand there and watch for any leaks while its running. careful not to get your hand caught in the fan.
From: Nashville TN. I can help you if you're close BUT NOBODY CAN HELP YOU IF YOU DON'T FILL YOUR LOCATION IN!
Good posting. Quick, simple, to the point, and not open to conjecture or conversation.
