General Electrical & Lighting Related Topics Ask here for electrical, wiring, and lighting info for your rig that could apply to all years
hid kit with hid(low) halogen(high) to bi-xenon
Old Dec 21, 2010 | 09:53 PM
gary96360's Avatar
hey, im tired of my 10,000k bulbs. theyre way too blue which makes everything hard to see. i was checking ouut some bi-xenon bulbs that are 4300k and i was wondering, do you need different ballasts or wiring for the bi-xenons to work?
Old Dec 22, 2010 | 12:41 AM
sabreuk's Avatar
No you should be able to just swap the bulbs over as it's the element inside the bulb that will change to the lower output rather than the ballast box changing to a lower input. So just change the bulb.
Old Oct 12, 2011 | 04:30 AM
gopher_6_9's Avatar
Yes, the ones I have seen in the past did require differant wiring.
Sabreuk, he is talking of going from a HID only bulb (only one beam) to a HID/Halogen High/low bulb setup.
Old Oct 12, 2011 | 04:49 AM
xxxtreme22r's Avatar
I believe they need different ballasts. The bi-zenon bulbs are only single filament, the way they work is a little shroud in the bulb activates and re aims the beam. It does not get brighter like a standard dual filament bulb.
calderp
Engine Swaps
Aug 16, 2016 05:15 PM
dumpster84
Apr 30, 2016 06:03 AM
Ironmike4x4
Feb 3, 2016 11:13 AM
calderp
Jul 27, 2015 09:58 AM
kyletbert
Jul 17, 2015 11:39 AM
