97 4Runner 2.7 coolant issuses
My mom drives a 97 4Runner 2.7/auto 4wd.
For about a year now there has been on and off overheating issues. The coolant in the rad/overflow looks like dark red clay consistency. It has been flushed now at LEAST 20 times, with no change. The trans fluid level and color/smell, everything does not change, nor is the motor oil. So I don't think the rad itself is mixing ATF/coolant. And that the oil is not mixing with the coolant.
Sometimes under hard acceleration / pulling a tough grade, gargling and a loud sucking noise can be heard behind the dash / heater region. And as of late, there is no heat from the front. (blocked heater core?) But the rear heat works fine.
I don't know what I should replace for her? I would love to start fresh with new rad/hoses/heater core, but I really don't know what the source of the problem is.
Any ideas?
Any ideas?
I would really look into the getting an external trans cooler, when possible.
Always back flush a radiator
You'll be surprised how much more comes out.
How old is the water pump?
Check under the oil cap for chocolate milk looking goo for a head gasket issue...
Has the water pump ever failed in operation? My parents had an heating issue after a failing WP, I back flushed it and tons of metal debris came shooting out. They havent hadnt an issue since.
You can physically test a thermostat with a pot of water on a stove and a thermometer...or replace it
I have no idea about the front heat and rear heat. Not sure if they share heater cores. The only thing I can think of is that one of the levers for the front heat is stuck or broke.
You'll be surprised how much more comes out.How old is the water pump?
It has been back flushed numerous times
Stocker
No oil or ATF change
Again, WP is Stock as far as I know
Thermostat and housing have been replaced
I have no idea about the front heat and rear heat. Not sure if they share heater cores. The only thing I can think of is that one of the levers for the front heat is stuck or broke.2 separate heater cores, I'm thinking the front is clogged with this "red clay" crap, at least this is what the gargling/sucking noise is telling me
You'll be surprised how much more comes out.It has been back flushed numerous times
Stocker
if the heater core is clogged.. then the radiator is done for as well. Replace both and use only toyota red coolant. That clay can happen when someone mixes green with red coolant.
Now say I get a new rad, heater core, hoses and such...How would I go about getting this clay like crap out of the block as to not start this all over again running it through the new parts?
Also, what else besides Toyota brand red? Whats it's equivalant at the big name stores (Autozone, Napa, Advance Auto, etc.)
Isnt the rad. aluminum? And the lines copper? How do they rust/rot? Or is the mix of red/green coolant by the PO eating them away?
To the OP: Front and rear have separate cores, heat valves, fans, water lines and air controls (front only). So all these are your prime suspects on front heat problem, although I assume fan is running. I haven't done it on a 4Runner, but I have done the garden hose flush on a heater core (switching back and forth with a drain hose. You just have to identify the inlet and outlet hoses. A little compressed air at the end followed by a half gal of distilled and some more air will get that evil hose water out.
The overheating is thermostat, radiator, water pump, or engine water jacket. Fan clutch should also be ruled out. The first four are in order of difficulty. So first change or test thermostat.
Then the rad. I don't get the no change in fluid deal. Is it shiny red when you put it in, and then gets like clay 20 times right away? What happens when you pull bottom hose and stick a garden hose in the top? (Get over the distilled obsession, if you have it, you've got bigger problems and almost all the hose water will drain out.) Is there good flow? How does it look at the top? If not flowing well and looking good, swap it or send it to a pro. If all good so far, consider WP/timing belt change. How many miles on TB and WP? Or, at the least, pull the cover and look at the WP. Any sign of leakage and there's your problem.
You just have to hope that the problem, whatever it is, is not inside the engine. That will not be fun.
I'm not sure what they are, but in the pics I have seen they corrode from the outside in, and in high salt places. The lines (in the pics I saw) were fine where not exposed to road spray. My guess is aluminum, not copper.
"No change in fluid" was to clear up the quick readers jumping right to headgasket conclusion. As well as the trans cooler mixing with the rad.
Flushing the system never netted true 100% clear H20. Was always tinted red/rust color. And within 2-3 days, was back to clay color & consistency.
The no heat deal has to be due to the core being clogged. All is well on the electrical/cable end of the heating system. One day there will be heat, the next none. There is a "sucking a milkshake through a straw" sound from the center of the dash, usually followed by a rush of fluid sound, followed by some heat.
Im going to say the PO mixed red/green coolant and created this beast of a mix.
While I can't find an official statement of the make-up of Toyota Pink, there are a number of sources out there that agree that it is a phosphated HOAT coolant with no silicates or borates, as is the Zerex Asian Formula. Google away, I did. Read the BITOG Coolant sub-forum. ZAF is the only after-market coolant that can say that. To be precise, I should have said it is the same base coolant, the same anti-corrosion technology, avoids the same ingredients that Japanese engineers reject-silicates and borates--and is the same color and the same strength.
Thermostat has been changed twice, there is a Failsafe in there now FWIW.
Poncho0206
Jul 10, 2015 06:21 PM
Avenged
Jul 9, 2015 07:55 AM
