22r idles but dies when i give it gas
86 22r automatic had been sitting for a couple years. Got it running but it ran like crap. rebuilt carb, new fuel filter, timing chain guides, checked cam chain timing- still ran poorly.
Took a carb off of a perfect running 22r 5 speed- still runs like crap
good compression, no smoke
good plugs, wires, cap, rotor and gas
WIERD- it dies when i spray starting fluid in the carb while it is idling?
ok it is definitely not filling up the float bowl. I pulled the fuel line from the fuel pump to the carb and it is pumping fuel. then i pulled the top of the carb checked the float and it is moving smoothly. Sprayed carb cleaner in to the fuel inlet and it was coming out at the needle.
What am I missing?
What am I missing?
Jnkml
Jul 6, 2015 01:20 PM
