Airlift onboard air with air shocks
Old Nov 12, 2010 | 05:21 AM
RyanJ989's Avatar
Thumbs down Airlift onboard air with air shocks
Hey guys, don't think this has been discussed. A long time ago I purchased the Air Lift 1000 air bags with the LoadControler I system. It had the airbags with an air compressor that you could control the air pressure from the cab. Slick little unit for only about $100 or so. Now, my question is that can I take the air bags out (have a leak in one) and then install Monroe, Rancho, etc. air shocks in and us the onboard air compressor I have to control them? They seem to use the standard air hoses and connections, and the gauge goes up to 120psi, I think. I have had the airbags up to 35psi no problem (that's the limit of the bags), so I don't think the air compressor will have a problem with air pressure. I also have a standard air valve in line so I could always air them up even if the compressor died. So, oh wise and resourceful forum, what do you say? Can it be done? Thanks for all your help!!
Old Nov 12, 2010 | 06:44 AM
blake.nemitz's Avatar
i say give it a try and find out, sounds reasonable enough i would go for it
Blamalam
Mar 12, 2022 07:34 AM
justdifferentials
Just Differentials
Sep 17, 2015 06:14 PM
punks_is_4x4
Aug 21, 2015 01:35 PM
94ofCanada
Aug 14, 2015 06:37 AM
terminator
Jul 27, 2015 07:13 PM
