Loud rattle when I push the clutch (22RE)
I have a loud rattle that happens when I am switching gears while driving. It almost sound like the engine, but it only happens when i push the clutch to switch gears. It only last for a second, if i keep the clutch pushed in it it wont do it. Any ideas?
Not sure, I will have to check and see. It sounds like the same sound that my engine makes when I start my truck for the first time in the morning. It has a loud rattle for a few seconds, but once the oil gets to flowing it stops. There is a certian RPM where my engine will make a rattle but only for a few seconds. It does it on the while reving up and stops once I get past that certian rpm and does it again on the way back down.
Mine used to do the same EXACT thing then a month later i threw a u joint after i replaced it never had the problem again! you might check it out....Also you might check you valves since you mentioned it not doing it after it warms up?
i had the same problem, it was almost tin sounding noise. i couldnt make the sound in my driveway only when i was driving so i looked around the bottom of my truck and it was my heat shield for my cat.
Timing chain rattling would come from the front of the engine. The driver's side guide is the one that breaks, this means that the sound can sometimes appear to be coming from the alternator. Another sign is that it can sometimes sound like a diesel when you first start it for a few seconds.
Check all of the heat shields on the exhaust. If any of them have broken bolts or if they are loose then tighten them up and see if the noise stops. My muffler rattles when I shift gears. It kind of sounds like a bike chain in a coffee can if that makes sense.
jasonty
41
Dec 23, 2018 01:00 PM
Sep 4, 2015 09:27 AM
Shaun Crystal Gomban
Jul 30, 2015 10:13 PM
HookahRoo
Jul 20, 2015 07:06 PM
