Need help with my subs, losing power
Ok guys info in my sig but the subs have been giving me problems lately. They stopped working the other day and I noticed that when I would hit a bump or dip while driving then they would turn on for a sec or two.
I parked and noticed they would once again come to life when I pulled the parking brake.
I realized the RCA cable is right below the parking break assembly so I crawled under the dash and tugged a bit on the RCA cable and the subs would come to life. So is my RCA shot? I unplugged it from the deck and connected it to make sure it was secure and still the same problem
I say poke your head out and make sure you didnt run aground in Scottland causing your lack of power issue.
OH Wait I reread your post and it seems its your stereo subs that are lacking power so it could be as stated above or even worse your sub/rear channel in your head unit/amp going bad bit it does sound like its the rca cables start there maybe you will get lucky and thats all it is
alright i took the deck out to look at the rca connectors and saw nothing physically wrong with them and the grounds were all good so i took it to a local audio shop and they tested it and it turned out that the deck was bad. so i swapped it out for another one i had and it works great!
but now i ran into another problem. it seems as if theres a white plastic area thing right behind the deck and this deck is slightly longer so the RCA connections are mashed right between the deck and the back wall. is there a way to make a little room back there?
you could try a set of right angle rca adapters, then they arent going straight out of the head unit, rather outa little then down.
http://cgi.ebay.com/5-x-Gold-Plated-...item3f0258ccfd
r3dfish
54
May 16, 2016 10:31 PM
Esibnitsud
Jul 30, 2015 08:19 PM
