85 4runner Leaking third member and bad vibration
My 4runner has had a vibration in the rear end for a while and recently it got really bad. It only vibrates when are giving it gas and i only really notice it going about 30mph or so and higher. when it got really bad i looked at my third member and saw it is leaking really bad right where the driveshaft ends at it. My u joint is fine but when i wiggle the driveshaft it feels loose just inside the third. This isnt much information but if anyone has an idea of what is wrong that would be great. If it helps, I do have a Detroit locker in it with 4.88 gears but they have never given me any trouble.
Thank you,
Thank you,
The pinion bearing is bad, or the pinion nut has come loose, either way you will probably need to replace the pinion bearing and gears if you have been running it like that for a while.
I was thinking about just looking on craigslist for a used third but then I got to looking and its going to be hard to find a third with 4.88s and a locker. And if I got one without one of those I would have to switch my front or go without a locker etc... Any idea how much it would be for a shop to install new pinion bearing and gear and how much the parts would be?
Here are some parts for your truck. From new assembled units to just parts.
http://www.wabfab.org/Differentials/...-products.html
Avenged
Jul 9, 2015 07:55 AM
FS[SouthEast]: 1st Gen 4Runner Slider Window, Driver Side
coryc85
Jul 6, 2015 04:07 AM
