808-5vz swap...
Old Sep 25, 2010 | 09:29 PM
808-3VZE's Avatar
808-5vz swap...
I'm in the middle of da Pacific ocean in Hawaii and i recently picked up a 94 4x4 3.0v6 pickup 5spd. I want to do a 5vz swap and found a 96 tacoma 3.4 preunner with a automatic trans. Wat parts do i need from the donor vechile to do the swap? Lmk i need all te help i cn get!!! ALOHA!!!
Old Sep 25, 2010 | 10:40 PM
Ahbustae86's Avatar
Howzit! I assume you want to keep it a 5spd standard? If so you will probably need the ECU and harness from a manual. I'd grab the whole donor in you can cause don't want to forget anything. I grabbed just the motor and spend a few hundred more trying to source stuff that I missed.
Old Sep 25, 2010 | 10:47 PM
theMonch's Avatar
Plenty of info...
You'll find just about everything you need to know here, although every swap seems to bring something new to the table.
I would start here at Off Road Solutions. They are out of business now, but nice enough to keep their site going.
http://www.offroadsolutions.com/tech.html
Andy Zook also has a great general info site here:
http://www.andrewzook.com/content/view/22/48/
From their do specific searches on each element of the swap and you'll get it all.
Firstly, change your signature to reflect your recipient vehicle and your donor vehicle specifics. This will help greatly in the future when you ask questions, as people will not have to ask the general questions over and over.
Not that that's said, the path of least resistance is to have similar setups (i.e. 5 speed to 5 speed) although using the auto setup you have is definetly not impossible. My initial advice is to search out someone here that is doing the opposite (auto to 5-speed) and arrange an engine harness and ECM swap.
Good luck.
Old Sep 26, 2010 | 07:47 AM
808-3VZE's Avatar
Howzit to you too!!! U from Hwawaii? lmk would be nice to see guys fom here doing the same swap. pm me bro!!!
Old Sep 26, 2010 | 07:53 AM
808-3VZE's Avatar
Good luck.
MAHALOS!!!
Old Sep 29, 2010 | 07:18 PM
808-3VZE's Avatar
Going to look at a 96 Tacoma 3.4 5spd truck is 100% complete nothing missing. Let u know how it turns out!!!
Rerun
3.4 Swaps
Oct 1, 2015 12:24 PM
RESmith711
Engine Swaps
Feb 14, 2015 04:34 PM
AH64ID
Feb 27, 2007 12:31 PM
TheTank
Aug 20, 2006 05:45 PM
