Pondering the idea of painting my Stock 2nd Gen Wheels
This is what I came up with in photoshop last night. Pretty decent rendering of what it *should* look like. Using Duplicolor's Graphite color wheel coating.
Might also do the center caps in a red to match the body paint.
What do you guys think?
Oh, that ugly faded graphic is gone now. (Yay for 3M Stripe-off wheel, contractor's solvent and a plastic putty knife)
So far I'm 80% convinced to do it. I do have a little curb damage I need to clean up before I paint though.
Does anyone know how tough this wheel coating is? Would a tire machine mess up the outer edge around the bead?
He's right, I painted a few things using that paint back in the day on my 2nd gen and didn't realize just how gray it was until it completely dried.
I would make sure you like the gunmetal look with the red before pulling the trigger.
I would also not paint the center caps red - IMO that looks a little "ricer".
Fink
http://www.rimpainter.com/
I was thinking about painting my wheels black a while back but I wasn't sure what exactly I would need and how to go about doing it. I also wanted a semi-gloss black instead of a gloss black or flat black. I talked to Christian at rimpainter and he actually put together a custom kit for me. The kits come with everything you need to get the job done properly and detailed instructions so you can't mess it up. I painted my wheels about 6 months ago and have had the tires balanced and rotated twice, and they still look awesome! I will post some pics when I get home from work.
As promised here are some pics of how my wheels came out. I got the kit from rimpainter.com and Christian hooked me up with a semi-gloss kit.
I'll have to re-match and see what it looks like.
Oh and Fink - don't worry, I won't do the center caps. A few guys at work have turned me off to that idea.
i thought about doing mine too. i just haven't had a time when i can let my truck sit for a full day for the paint to dry. i have lots of oxidation on the wheels and need to sand them a bit then i'm using rustoleum self etching primer then some black engine enamel then a clear coat. i did my spare tire with it and i think i turned out pretty good.
The steel wheels don't look too bad black. If I could find a full set of 'em I'd just put a black set of steels on my Runner.
So working around the fact that my computer is really slow today I was able to get a new rendering with the more grey graphite. Here's a comparison:
Graphite(ish):
Satin Black(ish):
Notice the side stripe is gone
I think I spent 3 hours the other evening polishing the crap out of the thing after I took the stripe off wheel to it.
Graphite(ish):
Satin Black(ish):
If you're gonna paint 'em, go with cheap walmart flat black. Is it great paint? No. But it will stick just fine, and by using a flat black as opposed to something shiny, when you do F- them up on the trail or something, it's real easy to touch up. Give it a shot, it dries and you're back to black again. If you use the shiny stuff, it takes a lot more blending to make it look right.
I did the same thing on my bumpers, mirrors, door handles, etc... everything else chrome on my truck. I'll beat it up, scrape it up, whatever. It doesn't really matter. It only takes about 30 seconds to fix it if it starts to bug me.
Haven't gotten this done yet. It's getting kind of cold around my parts too so I think this project might have to wait till the spring, or if we get a warm day - which in VA, isn't unlikely in the middle of December...
