Cheaper than a Powertank!
looks almost the same
i think i'm going to stay away from the co2 however, and build my own onboard air system, either with a stock toyota a/c compressor and fror oiler kit, or a york setup. i'd mount a 2gal air tank under the bed. costs: less than 200$ if you get the compressor cheap
2 gallon
tank isnt very big wont give you alot in reserve. might want to think about a bigger tank, a seven or eight gallon tank isnt all that big mine measures out at 8" x 22". got it from a truck/ trailer shop. As in big rig.
edit. they also have air switches which turn the compressor on at 90 psi. and off at 120 psi.
yimbo
9
Aug 22, 2015 03:36 AM
