Sponsored by: CARiD
How do I get the new CV joint in?
Old Jun 7, 2010 | 09:06 PM
dirtrider250's Avatar
Arrow How do I get the new CV joint in?
I'm replacing the cv joint on the driver side of my 93 yoder. With some pounding the old one came out. I got the shaft of the new cv slid all the way in but I cannot figure out how to slide the top over the bolts. I've looked at some threads but from what I've seen everybody replaces ball joints at the same time. Is there any way to get this damn thing on without taking everything apart???
Also, is it pretty normal for the 3.0 to stumble pretty good when started cold? I put new cap, rotor, plugs, wires, air filter on it to find I had wasted my money.The engine has 200k on it assuming it hasn't been replaced.
Old Jun 7, 2010 | 09:23 PM
rusche's Avatar
I usually roll the front diff until I can get the bolts to line up. Its a bugger. Can be done though. Just takes some tinkering.
Old Jun 8, 2010 | 01:43 AM
91 4Runner's Avatar
You could also do the "Quick Change CV mod" This makes changing them really easy...
Knock out the studs and either replace them with the same size grade 8 hardware or grind the splines off the studs and re-use.
But it can be done the way it is, just a big PIA!
Old Jun 8, 2010 | 04:05 AM
clydehatchet's Avatar
just leave em out! dont even bother... just throw em in the trash
Last edited by Lysmachia; Jun 8, 2010 at 04:35 AM. Reason: edited for inapropriate content
Old Jun 8, 2010 | 07:51 AM
iselloil's Avatar
Just seperate the ball joint or unbolt it.four bolts and then move the spindle.
Old Jun 8, 2010 | 08:15 AM
scuba's Avatar
Hit it with yer purse
Old Jun 8, 2010 | 08:21 AM
iselloil's Avatar
That hurts !!!!!
Old Jun 8, 2010 | 09:47 AM
swampfox's Avatar
have you tried removing the bolt and separating the lower ball joint and spindle ? i may be be wrong but if i remember right on a t 100 the ball joint had grove for the bolt to go threw ,and it was designed to come apart. i don't know if it the same on your truck.
Old Jun 8, 2010 | 08:46 PM
Thanks, had to take those bolts out but got it in.
Old Jun 8, 2010 | 09:22 PM
tebro27's Avatar
In regards to the stumble when cold try disconnecting the vacuum line going to the EGR valve. Plug the line with a golf tee or screw. On my toyotas in the past it has gotten rid of the stumble.
Best of luck!
kawazx636
Oct 6, 2021 03:03 PM
ladybugRC
458
Aug 21, 2020 10:41 AM
4x4YOTA
Aug 23, 2016 09:08 AM
crash813
Sep 27, 2015 07:15 AM
Odin
Sep 26, 2015 06:56 PM
