Cant get truck into 4 wheel drive
I have a 95 pickup with a manual transmission. I was down on the beach today and decided to throw it int 4x4. The only problem was i could not get the little shifter to go into 4. I tried and tried ,locked and unlocked the hubs. But it would not go in. Any ideas what the problem could be guys.
if the clutch was done recently .. i'm wondering if the forks were properly positioned when they put the transfer case shifter back in. Assuming they pulled the shifters to drop the transmission.
yeah i was kinda thnking the same thing.. everything else has been working just fine though.so i assumed there was no problem there. is there anything else you can think of. it was working wheni put it on the trailer to take it home and replace my head gaskets, and i had the clutch done about a week after that. this is the first time i have needed it since then.
pull the shifter boot from inside the cab, there will be 4 bolts holding the shifter plate. The shifter forks will look like two F s apposing each other. Take pictures and we'll try to help.
alright the shifters didnt come off with the plate. but here is a couple pictures of the 4x4 shifter at the base.http://s993.photobucket.com/albums/a...0.jpg&newest=1 and the next one http://s993.photobucket.com/albums/a...0.jpg&newest=1
picture fail thats whan i'm saying.. the shifter will come up with the base.. but thats not your problem problem would be the 2 rods you can see inside the hole where the transfercase shifter was.
alright good news guys. i called the transmission shop and they are gonna look at it next week and its still under warranty so il take it in and get it fixed.il post up what the problem was. Probably the forks..
wait a minute, before you get too far ahead...
where you trying to put the transfer case in 4wd while sitting still?
lock the hubs, and start moving in first gear; maybe 5-10 MPH, and then try to move the shifter into 4H
