NEWBIE Removing front rotors?
I've got an 86 4 wheel drive and need to replace the front rotors. Problem is I have no idea how. Got the wheels off and the calipers now the rotors. Any advice would be appreciated. Thanks.
you have figured this out I presume... there are holes for a bolt to be screwed in to "push" them out but if you are not saving the rotors then a rubber mallet works good to kind of 'beat' on them from the backside.
To OP, you need to pull the hub assembly apart. You NEED a 54mm socket to remove the axle nuts and reinstall them properly.
Follow the directions in the FSM closely.
It's not very difficult but it IS time consuming. Get used to the process as you should service your bearings after every time you submerge them as water always finds a way in =)
thanks for jumping in drew303. I was unaware on that gen all of that was needed. should have checked the wabbit link first. Just trying to be helpful for the newb and appreciate you teaching me something along the way, this is how I learn also.
Without torqueing the nuts properly... torq, spin, spin opposite, untorque, repeat... finish torque..
the bearings dont seat properly (as the grease creates hydraulic pressure, which you do this process to relieve it to get a PROPER bearing preload)... to prevent premature bearing failure. Which is only amplified by water contamination.
Buy the cheap socket and save yourself 100 bucks in bearings.
I personally leave mine torqued at 42lb but i believe the general accepted method is to torque to 42, do the spin method, release, torque..repeat..then leave the final torque at 20lb?
I like leaving it at 42 and havent had any bearing failures with this.
Sep 4, 2015 09:27 AM
crashburnoveride
Jul 10, 2015 06:39 AM
