oil in intake tube
Old May 27, 2010 | 09:53 AM
hopper's Avatar
oil in intake tube
My dad just bought a 2003 Tacoma with the 3.4L. There is oil leaking into the air box through the air intake tube. I pulled the upper air plenum and there is oil going down each tube. It is smoking pretty bad from burning the oil. Its been going through a quart about every 150 miles.
What could it be? I replaced the PCV so its not that.
Old Jun 1, 2010 | 09:34 PM
hopper's Avatar
no body has any ideas?!
Old Jun 2, 2010 | 07:11 AM
JMRAY23's Avatar
Do you have any oil leaking elsewhere on the motor? Id check your upper intake gasket between the plenum and the lower manifold. See if there is oil leaking beneath the plenum...keep us posted.
Old Jun 2, 2010 | 08:52 AM
hopper's Avatar
there is no other oil leaking anywhere
someone suggested a bad block but I dont see how oil can go from a cylinder up against the air into the intake tube and then into the air filter
Old Jun 2, 2010 | 09:53 AM
brian2sun's Avatar
Check that your PCV valve isn't plugged up or just not working, that's the usual cause. How does your valve cover look, any oil leaking from it?
Old Jun 2, 2010 | 09:57 AM
Kiroshu's Avatar
Air you sure it has a PCV valve installed? If so is it working correctly? <--If the PCV is properly working then its "blow-by" and is being cause by leaking valve stem seals or guides, or worn piston rings. Next step is to check compression.
Old Jun 2, 2010 | 01:52 PM
hopper's Avatar
Got a new PCV valve from Toyota and still same problem. How can oil go from a cylinder all the way up the "U" of the intake manifold and down to the air filter while fighting the air being sucked in? If there wasn't oil in the intake tube and just smoking then I would understand but to fight gravity to climb up into the air intake and against air flow doesnt make since to me.
Old Jun 2, 2010 | 06:06 PM
tunnelmotor99's Avatar
The PCV or Positive Crankcase Ventilation system is meant to relieve the air pressure produced in the oil pan and under the valve covers by all the moving parts. The pressurized air also has oil vapor mixed with it and the mixture is siphoned into the air intake to be burned off. This is why when you remove the upper plenum there is an oily black mess inside. If there is enough oil to leak back into the intake tube then you may have some blow-by or another engine problem.
Old Jun 2, 2010 | 08:11 PM
The4Rocker's Avatar
What he said above. I made an oil catch reservoir out of a air compressor water separator. It goes between the PCV valve and the throttle body. It is amazing how much oil it collects. This is usually where the oil comes from. I do not think it will hurt anything, but I hate the oil covering the whole intake system is why I installed mine. Maybe I can post some pictures...
Old Jun 2, 2010 | 08:12 PM
Kiroshu's Avatar
Crank case pressure will push oil out just as easy as it can pull it in from vacuum. Ifs its consuming oil and PCV system is fine then its mecahnical and needs engine repair as i stated earlier. "BUT" theres one more thing. Removing the vac line the PCV is connected to from the take while the engine is running putting your thumb on the hole of the vac line that goes back to the crank case does there appear to be "alot" of vacuum? Are you sure you plugs the Vac line in its correct spot? <-- IF all clear engine repair is in order. Whats the mileage and oil change intervals on your truck?
Old Jun 6, 2010 | 03:15 PM
hopper's Avatar
SLUDGE!!!!!!!!!!!!!!!!!
Took it to local Toyota tech and there is sludge galore.
Old Jun 6, 2010 | 03:27 PM
Kiroshu's Avatar
Ah wow. The sludge would mess with the crank case pressure and thus oil.... Good call on that tech.
Old Jun 6, 2010 | 03:29 PM
PismoJoe's Avatar
hahahaha
its funny because it didn't happen to me! (sludge)
Old Jun 6, 2010 | 03:46 PM
CYi5's Avatar
Gotta hate previous owners who just don't care enough to get an oil change...
Old Jun 6, 2010 | 04:01 PM
Kiroshu's Avatar
^Indeed
Old Jun 8, 2010 | 01:36 PM
When i worked at Saturn back in 08, this guy brought his 06 Vue 2.2L in for an oil change. We did it and he came back later that day saying it was overheating. I pulled it in and the rattling noise from the valvetrain was deafening! I pulled the valve cover and found the top of the head was caked with sludge, but what was interesting was the sludge had crystallized and completely clogged up the oil passages to the valvetrain. All the cam bearings had worn away and the cams had eaten into the head. He had just bought the car 2 weeks prior and fortunately he bought an extended warranty. Needless to say, he got a new engine! So that's what can happen if you don't change your oil for 38000 miles.
dumpster84
Apr 30, 2016 06:03 AM
adammtb
Jul 27, 2015 11:57 AM
colasurdo
Jul 18, 2015 07:06 AM
colasurdo
Jul 17, 2015 08:28 AM
87blyota
Jul 10, 2015 04:31 AM
