Yikes! VSC Off light, VSC Trac light and Check Engine light all at once.
Old May 3, 2010 | 12:01 PM
alleycat's Avatar
Driving along at 55 miles per hour and all of a sudden, the VSC OFF light, the VSC TRAC light and the CHECK ENGINE light all come on at the same instance. Truck seems to be running fine. Any ideas on what I have going on before I dive into this myself to try and diagnose??? 2001 4 Runner, 4x4 w/ lockable center diff. THANKS
Old May 3, 2010 | 12:33 PM
BigBallsMcFalls's Avatar
dive into an OBD II scanner and pull the code
VSC and TRAC almost always auto-disable when something else causes MIL to light.
Old May 3, 2010 | 08:53 PM
jimbob's Avatar
Check your gas cap - toyota failed to put a warning anywhere that a loose gas cap will light up the dash like a xmas tree. It cost me $100 to find that out.
Old May 4, 2010 | 06:57 AM
alleycat's Avatar
Thanks for the feedback. I had a scan done and it came back with a P1135 Code - Manufacturter Fuel Air Metering. I will check gas cap. Can anyone translate that code into plain engish for me?? Thanks
Old May 4, 2010 | 07:19 AM
Mauzer's Avatar
This should help ya: http://www.ncttora.com/fsm/1996/SIL/...fe/cip1135.pdf
Old May 4, 2010 | 07:20 AM
Beto's Avatar
"Air/Fuel Ratio meter heater circuit malfunction, Bank1 Sensor1".
Basically your front (pre-cat) Air/Fuel ratio meter has started acting up. They are costly ($200 to $300). Mine did this for a couple of months and I just drove around with my OBD tool plugged in all the time to keep resetting the code. Finally replaced the sensor and all is good.
Old May 4, 2010 | 05:45 PM
dallison's Avatar
o2 sensor
https://www.yotatech.com/forums/f2/c...ot-maf-208655/
bigjstang
Jun 2, 2025 03:56 PM
Jun 1, 2021 01:51 PM
Kalihi,HI
Jul 9, 2015 04:29 PM
God's Bounty Hunter
Jul 8, 2015 12:54 PM
colinmil
Jul 6, 2015 04:03 PM
