86 yoda pickup xcab build
Old Apr 25, 2010 | 03:54 PM
craneguy001's Avatar
Question 86 yoda pickup xcab build
ive got an 86 yoda pickup doing a v6 chevy motor out of a 05 astro van. i will be running 40 in tires on it so i got a matching set of chevy axels dana 44 front a 14 bolt rear with 8 in lift spring in the front not sure about the rear yet with teraflex shackels and king 18 in travel shocks all the way around. im wanting to convert the rear to disc needing to know what kind of brake booster and stuff like that i will need. i got the kit from advanced adapters to make the yoda manual trans and chain drive trans case work. are they going to hold up? if not what will bolt up to the motor and work. can i swap the spindels around to make it a high pinion and what kind of tie rods and drag links am i goin to need
Old Apr 25, 2010 | 04:43 PM
yoder519's Avatar
your probably not gonna get to many answers fro thsi build on this site, btu this things gonna be nasty when your done. i think sky manufacturing sells a kit to convert to a chevy brake booster.
Old Apr 25, 2010 | 05:02 PM
sky huh? got a web site this site has alot of answeres. alot more than anyone else thats why i gave it a shot. what are you runnin? the pic looks like you need a lift kit
Old Apr 25, 2010 | 06:37 PM
and i was thinking about a whole new universal 9 in brake booster. maby thats to much? i want the easy answer done right not the cheap presidental solution answer thats goin to kill me or someone else on the trail for this build. just like i did my 02 stang thatll eat cobras all day long here in okc.
Old Apr 25, 2010 | 06:50 PM
peow130's Avatar
I'd say you get a D60 in place of that D44. The D60 is a bit beefier, and since you're going to be running 40" tires you'll want the added peace of mind.
Old Apr 25, 2010 | 07:05 PM
my rig only weighed 2400 with the stock motor and axels im only adding maby 800 lbs to it its all fiberglass except for the cab thats the only thing oem becides the frame. it was origonally a prerunner but im trying to get into mud and trails more than dunes. aint a d60 a little over kill i thought 3/4 ton axels was goin to be enough overkill
Old Apr 25, 2010 | 07:16 PM
SpecialScottie's Avatar
Get on pirate4x4.com
Old Apr 26, 2010 | 09:07 AM
whats on there?
Old Apr 26, 2010 | 05:19 PM
yoder519's Avatar
i jsut had a 36in swamper settin up against it in the pic. Pirate4x4 is a offorad forum full hardcore guys runnin setups liek you wantin to run
Old Apr 26, 2010 | 05:36 PM
peow130's Avatar
The D60 has a bigger R&P, thicker axleshafts, bigger U-joints, and stronger knuckles.
You want to run 40" tires on the weaker axle, you're going to be spending alot of money beefing up an inferior axle. When you could spend alot less on the stronger one.
Old Apr 26, 2010 | 05:38 PM
yoder519's Avatar
what he said. if you wana run over a 37 and wheel hard, IMO full widths are the way to go. plus itd help out with the bigger engine, and be more stable on the trail
Old Apr 26, 2010 | 05:42 PM
peow130's Avatar
well he wanted full widths already.. the 14 bolt and d44.. however, the d44 is pretty weaksauce.
Old Apr 26, 2010 | 06:38 PM
o alright well how about the transmission and t case deal?
Old Apr 26, 2010 | 06:51 PM
peow130's Avatar
well.. if you don't mash the skinny pedal you should be fine.
the astrovan engine might have maybe 150hp over the stock engine.. so you should be safe with that.
i've seen guys back the toyota trans against a chevy 350.
now that i re-read your initial post, you already have the D44 and 14?
Old Apr 27, 2010 | 03:34 PM
ya i got the matched 3/4 ton axels last week from a guy that rebuilt them and delivered to the shop. i am doin a disc brake conversion on the rear and i guess all i have to do is get some special brackets from a local guy and use front callipers and rotors to make it work. but im wonderin if the stock brake booster is strong enough or do i need to get a better universal set up. so people are puttin a 350 with the stock yoda trans and t case with no problems huh? i got the conversion kit from advanced adapters that came with the bell housing clutch n flywheel. can you think of anything else i need?
Old Apr 27, 2010 | 10:38 PM
peow130's Avatar
Okay keep the axle then.
Might as well, right? It's already rebuilt.
As for the brakes?
Get a bigger bore on the brake cylinder. search thru the forums, theres all kinds of crap on it.
Yeah i know of one guy on here with a 350 in his 1st gen. I cant remember if hes running the stock trans though.
The transmission should hold up to that astrovan engine, though. It's only a V6. Just lay off the skinny pedal, no burn outs okay?
Jun 1, 2021 01:51 PM
sandyota
Feb 4, 2021 11:16 AM
icentropy
Sep 16, 2020 02:47 PM
Sep 4, 2015 09:27 AM
toyoda8488
Jul 5, 2015 10:18 PM
