What fan to use on a Hayden 679 ATF cooler?
To avoid participating in threads like this one, I am bypassing the stock trans cooler with a Hayden 679.
While I am not doing it necessarily for the cooling properties, I have noticed my ATF running between 185 and 195 degrees as of late, and we have not had hot weather yet.
Since I am doing the install anyway, I was wondering what fans some of you might have installed on this cooler to keep temps down figuring now would be the time to do add it when I have the grill off.
I've used motorcycle radiator fans on a few of them, you can get them pretty cheap (used) on ebay. Look for the ones that have a little cage around the fan blades. Or just get a new one from SPAL like this (note part number on box is for a puller).
Here's a couple of used motor cycle fans I got off ebay, don't ask me what they came from now I don't remember. Lots of cycle guys remove them to cut weight I guess.
kawazx636
Oct 6, 2021 03:03 PM
scott90
Oct 4, 2015 09:21 AM
runnermedic
13
Sep 21, 2015 05:20 PM
