oil pump issue
Old Mar 31, 2010 | 05:08 PM
MuddinRI's Avatar
oil pump issue
Ok finished my motor of sept of 09(22re). I think it leaked from the get go seems to leak right at the bottom between the 2 bottom bolts. It's only 8 months old and was bought from engbldr. I just took it all apart and put it back together with a new gasket and it is still leaking a little bit, was real bad before i replaced the outside gasket. Ok question how or why is this happening i checked the pump with a str8 edge seems fine. I'm stumped don't know if i should be calling engbldr or what to do. Any suggestions or anyone else run into this problem.
Old Apr 1, 2010 | 04:28 AM
bipolarandproud's Avatar
When I put my oil pump I used rtv silicone on one of the bolts ,If you don't it will leak . I also put a bead around the oil pump . You have to put rtv on the bolt above the front oil seal on the left side . .
Old Apr 1, 2010 | 08:21 AM
flyingbrass's Avatar
Are you sure the oil is coming from the pump/cover junction itself and not running down to there from the front seal?
Old Apr 1, 2010 | 08:28 AM
xxxtreme22r's Avatar
you know mine is leaking too. same pump around the same time of rebuild. I also got a whine in mine though too.
Old Apr 1, 2010 | 08:31 AM
That's another possibility , I remember that I had to buy a repair sleeve ( also called
" speedi sleeve" ) do a search on google . for the harmonic balancer . It just A circular aluminum sleeve that makes A tighter fit and stops it from leaking ,but that's only if it's leaking from the front seal.
-Rob
Old Apr 1, 2010 | 10:37 AM
MuddinRI's Avatar
i'm pretty sure it is coming from between the 2 bottom bolts. I did rvt the one bolt they say too. my harmonic balance was dry no oil on that so i think that seal is good, plus i can see the oil weeping from the area in question. i guess i can try to take it off and rvt around the whole pumps outer edge.
bigjstang
Jun 2, 2025 03:56 PM
Colington
Mar 8, 2020 09:51 AM
TURBOrunnerNM
Jul 22, 2015 11:01 AM
jon.r
Jul 11, 2015 03:34 PM
Huntingtruckcletus
Jul 8, 2015 05:26 PM
