engine oil flush? good? or damaging?
Old Mar 31, 2010 | 10:57 AM
516593812's Avatar
I'm about to change my oil, & I thought I'd flush the engine while doing this. My truck currently has no leaks, & runs great- I want to keep it that way, that's my main objective. Given that, would it be a good idea for me to flush it? I've read alot of stuff online sayign that the flushing products can knock loose gunk/ particles that can block the oil passages & cause oil starving, pressure issues. faulure, etc. If it is a good idea, what should I use? Is it oil based or more of a harsh solvent type stuff? I also read many places that unless I remove the oil pan & clean up the sludge that results from the flush, it won't be effective. I'd appreciate some experience here........
Old Mar 31, 2010 | 11:21 AM
mt_goat's Avatar
I'd just change the oil and filter at good intervals and it will stay clean. If you suspect you have a sludge monster read this: https://www.yotatech.com/forums/f2/o...ttacks-167704/
Cutting open your filters before you throw them away will sometimes show if there is a problem.
For one example: here's a filter from a BMW sludge monster with only 3000 miles on a regular oil and filter change (no flushing stuff added), read the whole story here if you want: http://www.bimmerfest.com/forums/showthread.php?t=94785
And if you ever see a filter that looks like this you have some real problems LOL:
Old Mar 31, 2010 | 11:48 AM
AzStorm's Avatar
This forum has all the info youd care to read about and probably more.
http://www.bobistheoilguy.com/forums...Board=5&page=1
Personally I use Seafoam in my fuel once in a while and have used both Seafoam and Marvel Mystery oil (not at the same time) to flush the motor.
Ive had no negative side effects and have noticed a bit smoother better running motor over the past 6 months.
Old Mar 31, 2010 | 12:12 PM
Kiroshu's Avatar
Just by exp I believe an engine flush is useless unless you are rebuilding the engine which in any case you would clean anyway... pointless. I've seen many motors start knocking because of "Engine oil flushes" I recommend not to. It doesn't say in your maintinece scheduale from toyota to flush engine every xxx,xxx miles so don't do it. Just change oil and filter at the required intervals and you will be fine. "Engine Flush"= Useless way for auto industrys to make money and nothing more.
Old Mar 31, 2010 | 03:48 PM
RustBucket's Avatar
I've done flushes with an Amsoil flush product before switching from dino to synthetic. They recommend putting on a new oil filter, adding the product, running for 20 minutes at fast idle, and then replacing the oil and filter again. I've never had a problem though I doubt frequent oil flushes are a great idea - better to just rely on the detergents in the oil.
RA8225
Aug 12, 2019 01:31 PM
ian1386
Jul 1, 2015 11:23 AM
metalmadness24
Jul 1, 2015 10:21 AM
XtremeOff-Road
16
Jun 27, 2002 07:32 PM
