Tool Time Discussions here pertain to the use of tools you use while fabbing and wrenching in the garage
Hobart 187
Old Mar 28, 2010 | 04:28 PM
atoy yot's Avatar
Hobart 187
Just bought the Hobart Handler 187, been usin the flux and welding some light steel getting used to it. Want to start welding some aluminum and am looking for some ideas- i need a bottle o Argon and the only place ive found is TSC and a small bottle is 143 bucks..... anybody know where i can get a bottle for cheaper? Rather not rent a bottle any opions would be great
Old Mar 28, 2010 | 06:58 PM
TC4RNR's Avatar
you need to spend quite some money if you want to weld aluminum. not just the shielding gas. aluminum is a lot softer then steel wire, it's almost impossible to push it all the way through a regular mig gun. you will need a spool gun, where the wire reel is located right by the gun, not the welder. that, will cost you around $400 for the cheapest 100amp gun.
http://www.brweldingsupplies.com/pro...roduct_id=1381
Old Mar 28, 2010 | 07:26 PM
snobdds's Avatar
Your set up for mild steel insted of aluminum. TC4RNR said it best...you need a spool gun with aluminum wire to weld aluminum with that machine.
Old Mar 29, 2010 | 02:08 AM
wyoming9's Avatar
Red face
It is a real shame that some companies sell a liner they say can weld aluminum it is all bull poop the only way is as stated with a spool gun or a higher end unit like the Miller 252 or 350. which can take the Aluma Pro Gun .
At best running at full output which reduces the duty cycle to almost nothing you would get very disgusted in a very short time.
Welding nice new Aluminum is not bad try welding something that is a few years old and exposed to the weather .
Old Mar 29, 2010 | 02:17 AM
TinMan's Avatar
Check google for a national welders supply in your area. Go in and talk to them for a little while see what they will do for you on a 160cu/ft bottle of 75/25. Gonna run you about $200.00. 75/25 will not do alum, but will get you covered for mild steel. Then you can save and practice for the alum regulator, spool gun, and cover gas you will need.
Old Mar 29, 2010 | 06:17 PM
atoy yot's Avatar
Thank you all did not know the spool gun costs soo much- thats a damn shame
James Woods
Oct 9, 2011 09:13 AM
JagerFiend
Mar 26, 2011 04:57 PM
toyospearo
Apr 3, 2009 05:15 AM
NCSU-4runner
Sep 12, 2008 12:00 PM
soarerjzz30
Oct 4, 2006 04:44 AM
