help! cv stuck in diff!
Old Mar 28, 2010 | 01:00 PM
boostedka's Avatar
ok guys the cv axle is ready to come out but it is stuck in the diff. I have been trying to pry with a pry bar but it does nothing. is there something else i need to do? every write up says it will just slide out....i have a 96 4runner 4wd
Old Mar 28, 2010 | 01:11 PM
Kerby J's Avatar
use a bigger pry bar like a 3 foot crow bar bc that is what i had to use to get mine out
Old Mar 28, 2010 | 01:17 PM
Gerdo's Avatar
Also try rotating the axle a few degrees, try again, repeat until it pops out.
Old Mar 28, 2010 | 01:54 PM
boostedka's Avatar
bought a new pry bar but it is to thick and wont fit so i can pry. used the old pry bar and tried rotating and prying and it didn't work...is there something holding this thing in t have to remove?
Old Mar 28, 2010 | 02:52 PM
Ironmike4x4's Avatar
I've came across this a few times at work. The best solution I've found is to use a pickle fork and a 5 lb. mini sledge hammer to jar it out. This only works if you are replacing the whole axle though and not just putting a boot. I would recommend buying your own pickle fork instead of using a "loan-a-tool" from autozone or somewhere because you WILL damage the prongs on the fork.
Old Mar 28, 2010 | 03:04 PM
boostedka's Avatar
ok i got it off thanks for the help. now the new one wont go in...is there a special way it needs to be to insert into the diff?
Old Mar 28, 2010 | 03:42 PM
May have to turn it a bit, make sure it's the right one. Measure the old cv shaft and compare it to the new one. Depending on where you got it from (autozone, napa, etc.) they may have given you the wrong one.
Old Mar 29, 2010 | 03:28 AM
Bird-Doggin's Avatar
I had trouble getting mine to go in when I replaced them. I found that the retaining or snap rings that are located on the end of the shaft were spread out too far. I took them off and put the old snap rings on and the axle popped in with no problem. Good luck.
Old Mar 29, 2010 | 05:04 AM
hross14's Avatar
You can also put it in as far as it will go--then refit the knuckle/hub and press on it to get it to go in--
You seem to be having alot of problems
Old Mar 29, 2010 | 06:23 AM
exrunner's Avatar
Also, try to put the snap ring on top of the axle, when its hanging down below the axle it sticks out farther and is harder to get the axle in all the way.
Old Mar 29, 2010 | 06:36 AM
gpcollen1's Avatar
Yeah, much of this is covered in writeups here and there. Give it a whack...
live4soccer7
May 11, 2016 06:52 PM
Badlander
Oct 10, 2015 08:05 PM
Odin
Sep 26, 2015 06:56 PM
toyotasaurus
Sep 24, 2015 03:30 PM
zz_denis
Sep 6, 2015 03:43 PM
