downey springs + cranking T-Bars= 33's?
Old Nov 11, 2003 | 01:19 PM
my95toy's Avatar
Hey guys, i've read up all the posts about 33's and i undertstand a 1" bl will allow 33's to fit on my 95. My question is can i get a satisfactory amount of lift from putting downey coils in the back and cranking my t-bars? fender trimming is also no problem. I'm just trying to save as much $ as possible cause im a broke ass student. Any info helps, Thanks
Old Nov 11, 2003 | 01:23 PM
Flygtenstein's Avatar
Don't crank the torsion bars.
Look at the front end of this pic. Aftermarket t-bars with a mild, as in around 1/2" of crank. Rear tire is completely flexed, front end is completely load. Notice how you can still see the top of the bumpstop?
Old Nov 11, 2003 | 01:33 PM
my95toy's Avatar
i'm not understanding what your trying to say.
Old Nov 11, 2003 | 01:47 PM
CTB's Avatar
CTB
Adrian's just saying that if you crank the torsion bars, you are going to have a stiff front end (espeically without adding any additional weight up there), and it will make your front-end flex decrease.
Old Nov 11, 2003 | 01:48 PM
UKMyers's Avatar
He's saying that if you crank the T-bars you lose what little flex there was in the IFS. Under optimum conditions you should run out of flex when the A-arm hits the bumpstop. Usually this is not the case though. Flygenstein can you chime on this one too?
Old Nov 11, 2003 | 02:17 PM
I mean that in the pic, you can see that the front is not running to the compression bumpstop meaning that not all of the paltry amount of travel is being used.
Do not crank the torsion bars is the end lesson. If you have two or three fats guys riding on your hood at all times, consider aftermarket bars and or mild cranking.
nvdesertrunner
May 11, 2020 08:18 PM
JHalcyonM
Aug 4, 2015 01:19 PM
coffey50
Jul 28, 2015 10:55 AM
CanRunner
Jul 20, 2015 01:29 PM
redneck17
Jul 17, 2015 07:44 PM
