Just Cut Off
Old Nov 11, 2003 | 04:29 AM
cand1ed0g's Avatar
Just Cut Off
I just purchased a 2002 4WD V6 Tacoma with 24000 miles. I love the truck. However, I was driving to work today when the engine just cut off. To be more precise, I was doing about 60 when it happened. No stuttering, no choking, nothing. I just went to apply gas and nothing happened. Looked down and noticed that the engine had cut off. I coasted to the side of the road and restarted without any problem and haven't experianced it again. Any of you have a clue as to what it could be?
Old Nov 11, 2003 | 04:40 AM
rimpainter.com's Avatar
I would check all electrical connections in the engine bay. Battery, alt, etc. Very strange indeed. Do you have an alarm w/ a kill switch of some sort?
Dont rule out fuel delivery issues either, though unlikely.
Old Nov 11, 2003 | 05:46 AM
cand1ed0g's Avatar
I had a loose cable on the positive post. I thought I had tightened it down. Is it possible that it came loose, then reseated itself. I was under the impression that if the battery did fail the engine would keep running. No?
Old Nov 11, 2003 | 06:04 AM
Well not necessarily. The alt recharges the battery. So, you theoretically could have dropped below the required voltage to run the engine because the cable was not "touching."
That should take care of your problem.
Old Nov 11, 2003 | 10:50 AM
Sac State's Avatar
Dirty fuel or filter? At 24,000 miles your filter should be fine though. You would have prolly sputtered if it was fuel delivery related.
Do you notice a high pitched whining noise? Might be your fuel pump. I had a 2000 Ford Exploder that had the fuel pump in the gas tank die.
Old Nov 12, 2003 | 05:11 PM
alanh's Avatar
If your negative batt terminal was loose, it would be like disconnecting the battery and the books say never disconnect the batt. while the engine is running. Probably caused a nasty hickup in the electrical system. A search would probably find the details I don't remember, but apparently electrical damage can result, so you may be lucky.
Alan
Old Nov 13, 2003 | 07:11 AM
cruizin01's Avatar
certain vehicles might be different but I dont think disconecting the battery would kill the truck. My buddy had a k5 blazer. We jumped the truck without a battery and let it run for a few minutes. I wouldn't suggest this (I was told it would really screw with your alt, I dunno if it throws it on full charge or whatever) but just thought I would throw that out there.
kawazx636
Oct 6, 2021 03:03 PM
ladybugRC
458
Aug 21, 2020 10:41 AM
live4soccer7
May 11, 2016 06:52 PM
Thamuel_
Domestic Swaps
Oct 3, 2015 11:15 AM
dbollier123
Sep 29, 2015 05:23 PM
