New timing chain probem 22re
Old Feb 17, 2010 | 07:57 PM
carguygt500's Avatar
I am in the middle of re-assembling my 22RE after a head gasket replacement. I have a new timing set installed and I cannot get the cam sprocket to slide back onto the camshaft. Are their any tricks to give me a few extra millimeters of clearance?
Old Feb 17, 2010 | 08:55 PM
bernd's Avatar
This write-up has some tips which may help:
http://www.4x4wire.com/toyota/maintenance/timingchain/
Old Feb 18, 2010 | 10:41 PM
Got it back together. If you rotate the crank back and forth while applying upward pressure to the cam gear you give yourself some more slack in the chain.
Old Feb 19, 2010 | 01:43 AM
TORTIS's Avatar
but was your crank TDC when the chain slid in to the cam sprocket?
Old Feb 19, 2010 | 08:16 AM
Jay351's Avatar
slide a small punch into the hole in the cam and rotate it just slightly to make it easier to slip the cam sproket on.
Old Feb 19, 2010 | 08:46 AM
dfarr67's Avatar
I have a long screwdriver that reached down to the tensioner which slid it back- also used a 1/2in extension with a larger socket to guide the sprocket on- nice n tight.
Old Feb 19, 2010 | 06:55 PM
tnig's Avatar
make sure you didn't put a wrong size bolt on the TG cover/oil pump cover. The bolt that goes in right under the timing tab should be a short one or it will interfere with the tensioner.
Old Feb 20, 2010 | 07:17 PM
thanks for all the responses. I just started the truck tonight and everything seems to be in order. Only noises are the squealing of a bad power steering belt tensioner and the valve lash is a little too loose but I'll take care of all that tomorrow. Thanks again guys, let me know if I should continue to check anything over the next few days to make sure its running right.
steve miller
Oct 10, 2015 01:40 AM
Nickdigg
Jul 7, 2015 06:04 AM
bryan34w
Jul 6, 2015 05:53 PM
