Brake ?? after lift
Brake ?? after lift
I have looked and can't find the answer I need. I have an 89 4Runner w/3.0. I installed a set of used lift springs in the back. I think they were suposed to be 4" lift. My question is what do I need to do about my E-brake cable. It appers to be kind of tight now. I have not done a full drop test of the rear end yet, but form looking at it I think I will break the E-brake cable. What to do???? Also what do I need to do to the rear brake adjusting lever??? Sorry if this is long and confuessing. Thanks for your help. Bryan
I think you can adjust the e-brake cable but haven't looked at it to be sure. I do know you can adjust the LSPV bracket on top of the axle housing alittle or you can fab up a plate to lift it up a couple of inches.
There is a mount on the rear axle for the LPSV.
Make an extension for this mount by getting a piece of flat stock. drill two holes to match the factory mount, and then drill one hole 4" (or how ever much your lift was)
from the upper hole that you drilled.
This will raise the LPSV 4" from stock and restore the LPSV geometry.... Link to trailmaster (PAGE 11)--- http://www.trailmastersuspension.com...ions/TP100.pdf
Flying91
45
Apr 11, 2024 04:39 PM
Jun 1, 2021 01:51 PM
Sep 4, 2015 09:27 AM
