wheel spacer recommendation
Old Jan 29, 2010 | 02:51 PM
rideexileex's Avatar
I just picked up a set of 285/75/r16 BFG AT's on the stock fat 5 spoke 4runner rims and am worried about the very small amount of clearance left between the A-arm. I want to get a 1/4" spacer - any specific recommendations/cautions? Thanks
Found this while searchin the forums - good enough?
http://www.jcwhitney.com/jcwhitney/p...41&zmap=816450
Old Jan 29, 2010 | 04:14 PM
Elton's Avatar
1/4'' spacers from wheelers works fine for the front
Old Jan 29, 2010 | 04:28 PM
Truckfiend's Avatar
I personally would not but free floating spacers. You will have to get extended studs and no mainstream tire dealer will touch your truck with free floating spacers due to them being a safety issue. I would recommend bolt-on spacers but the smallest you can get those is 1inch. WabFab sells some good ones.
Read this.
https://www.yotatech.com/forums/f37/...mudder-193684/
Old Feb 1, 2010 | 09:12 AM
brian2sun's Avatar
Lots of people run 1/4" spacers w/ no problems. The factory lugs are long enough for 1/4"ers.
Old Feb 1, 2010 | 09:38 AM
kawasakimoto_7's Avatar
yes factory lugs will work with 1/4 spacer but like truck fiend said no tire dealer will touch it, i work for americas tire co and we send people home all the time cause they have non bolt on spacers, oh and they make your truck vibrate at freeway speeds and under high pressure on breaking. i would never put a free floating spacer on... thats just my opinion.
Old Feb 1, 2010 | 10:21 AM
brian2sun's Avatar
I have two very high quality 1" bolt-on, aluminum, hub-centric spacers (w/ the extra 12 lug nuts) I'll sell for cheap. PM me if you want them.
TJWilly
Jul 31, 2015 02:05 PM
coffey50
Jul 28, 2015 10:55 AM
terminator
Jul 27, 2015 07:13 PM
Yotoder865
Jul 9, 2015 07:51 PM
