Herculinered the back of my 4Runner
Old Jan 9, 2010 | 03:11 PM
airkewld4life's Avatar
Well, I just put down the first layer of Herculiner in my 4Runner and I am very pleased at how good it turned out.
The back of the 4Runner after I stripped the carpet out
The notorious tar boards
After the air chisel action
Testing the tar removal products
After letting the products set
The end result
The WD40 penetrated the best, while Oops was the worst because it dried up too fast.
Now, on to the Herculiner
I started with the edges and worked toward the center. The kit included everything needed to apply the liner but I also needed a surface prep/cleaner, a paint pan and stirrer.
Halfway done
First coat completed. Will lay a second and see how I like it
Old Jan 9, 2010 | 03:16 PM
elblako91's Avatar
Nice.
Old Jan 9, 2010 | 03:29 PM
MaK92-4RnR's Avatar
looks good, I might do that haha. I have subwoofers though... that'd rattle like a mofo.
Old Jan 9, 2010 | 03:31 PM
I don't think it would rattle much more than it does now. After 2-3 coats it should be pretty solid.
I plan on putting a sub in mine.
Old Jan 9, 2010 | 03:35 PM
MaK92-4RnR's Avatar
mine doesn't rattle but thats because I have dynomat and carpet under it. hah
Old Jan 9, 2010 | 03:44 PM
TORTIS's Avatar
Looks like a good start. I really need to do the bed of my truck!
Old Jan 9, 2010 | 05:00 PM
It was super easy. Hardest part was removing the tar boards. The kit came with a gallon and I didn't even use 1/4 of it after 2 coats.
Old Jan 9, 2010 | 05:56 PM
TORTIS's Avatar
I think I saw that stuff at O'rielly's for 89 bucks. I'll put it on my spring projects for my truck.
Old Jan 14, 2010 | 08:37 AM
the_slug's Avatar
How good of a sound deadener does the Herculiner make?
Would it be worth finishing out the rest of the interior and then putting the factory carpet back down in the front?
Old Jan 14, 2010 | 08:55 AM
Lumpy's Avatar
good deal!!! I did all of mine not just the back and I love it!!!
Old Jan 14, 2010 | 01:43 PM
I'm not sure yet. I'll take it out for a spin to compare the difference. It's not registered right now so I can't go far, just around my neighborhood.
I'll post up when I know.
Old Jan 16, 2010 | 11:59 AM
Ride report: Honestly, I heard no difference in noise driving it with the windows up and sunroof closed. If anything, it was probably a touch quieter as I heard my leaky exhaust less.
Also, I'd like to note that I kept one of my Craftsmen toolboxes in the back while I drove it around and took corners semi fast to see if it would slide, it maybe moved an 1/8 of an inch. Highly recommended.
Old Jan 16, 2010 | 01:13 PM
93yotaSR5's Avatar
wow looks good. i might try it myself.
Old Jan 16, 2010 | 01:14 PM
Thanks. I definitely recommend it if you use the back of your Runner or truck bed a lot.
Old Jan 17, 2010 | 01:06 PM
yotarover's Avatar
i like, i just did the inside of the cab i used some cheaper rustolem undercoating from walmart. at $3.94 a can so and it's perfect so far i've done 2 coats
Old Jan 17, 2010 | 07:09 PM
JShaffer0525's Avatar
anyone else looking to do this avoid the duplicolor bedliner crap. spend the extra money for the herculiner. i used the duplicolor in my 4runner and its chipping up.
Old Feb 12, 2010 | 08:02 PM
Mountain Cop's Avatar
Are you guys all chipping the tar boards out first? I'm considering leaving them in and just going over them with the Hurculiner. Mine seem to be pretty well attached, and I haven't found any rust on the truck yet, so I would think that there wouldn't be any under the tar. Thoughts?
MC
Old Feb 12, 2010 | 09:00 PM
Tracey98277's Avatar
MC
i did mine over the tar board. i can't tell the difference between mine and the ones without tar board.
Old Feb 13, 2010 | 03:57 AM
dwest76's Avatar
Noise
Is there a big difference in the noise level inside the cab?
Old Feb 13, 2010 | 07:13 AM
I don't notice a big difference. I don't think it's louder by any means
