My new 85 SR5
My new 85 SR5
Picked her up a few days ago for 1200,not to shabby
. Bed is shot. As you can see I've done the cut the body line off the bed mod. And a lockout on one side and an auto on the other
1200 sounds like a lot for me. but i got my 88 in similar condition for 200. dosen't bed rust suck. just got the body work finished and the bed primed tho. good as new. o but i forgot, the 85s got solid axles right? nice.
has anybody ever used some S-10 ZR2 rear springs for a spring swap on a toyota????
idk how long they are..but they should give quite a bit of lift..since they are spring under and give about 3-4" of lift to the S-10..put em on a toyota and they should net about 6" of lift..or 7" lol
Check out SKY's for the 63" conversion brakcets and such...you have to move your front hanger forward..and i think either move your rear shackle back..or use a long rear shackle..or like a double shackle setup
its only a budget lift if you know how to weld.... otherwise it gets expensive, get rough country for budget, take out a couple leafs in front and put a couple of your softer stock leafs into the pack it will allow you to flex more, with shocks its about $350 easy to install takes about 8 hrs by yourself
FS[MidAtl]: 2000 Tundra (Parting out) Pennsylvania
ToyotaMD
Nov 9, 2015 11:53 AM
