Front end shake from 60- 65
Before you guys say anything, I have searched this. I drive a 91 4Runner, 3.0, 5 speed, and of course, 4x4. I have recently noticed that at 60 miles an hour, there is a pretty hefty shake, that continues up to 65. Now, as soon as I reach 65, the shaking stops, and I can control the truck better. I read a thread about doing a mod on the steering rack bushings, but I don't know if I have a rack & pinion steering system or not ( I'm still learning a lot about this stuff). Let me know what you guys think.
I recently had the tires mounted on some different wheels( I call them rally wheels, but I don't know if that's correct or not) and they supposedly balanced them then, but you never know I guess. Thanks for the tips guys, its appreciated. Abe, how do I find out if I have a steering dampener? Is that something that came factory, or is it an after-market thing? Thanks again guys, and as before, I am still learning a lot about these trucks.
These trucks are easy to fix once you understand their idiosyncrasies.
So by your post above, the shake started after you had your tires mounted on those new wheels? Out of balance wheel, bubble in the tire plies (IE time for new tires), or a bent rim would be where I would start. Rotate the tires from front to rear one side at a time and see if the shake changes at all, and you may find your culprit wheel...
i agree with "thedanned" i was just throwin' that out there seems like alot of people buy the whole part when they could rebuild the one they have but your prob is (imo) somethin to do with those wheels or tires or it could be a steering component you can always just climb under there and look it all over good make sure there's no excessive wear
FS[GreatLakes]: Toyota collection part out
88sasturbotoy
Jan 30, 2026 01:57 PM
Flying91
45
Apr 11, 2024 04:39 PM
jasonty
41
Dec 23, 2018 01:00 PM
v_man
Jul 23, 2015 04:01 PM
