burning oil through rings or valve seals?
What's the best/easiest way to tell? I've got minimal oil leaks (one through either rear main seal or the tranny seal) and that is it (just a little oil is leaking from this spot and I believe it is the tranny), yet I'm still losing oil. It must be burning it. Would a leak down test show this? haven't done one before and am not too familiar with it, but a little input may help out push my research in the right direction.
Yeah know, I'm not really sure. I've had it in the garage for a while and I'll have to check it out once I get it back off the stands. Just curious, but what is the reasoning behind the valve seals and shifting?
it has something to do with when you push the clutch in it takes strain off the motor and oil leaks in. to be honnest i'm not really sure but that what was wrong my buddys truck and also with mine
jasonty
41
Dec 23, 2018 01:00 PM
rushw
Jul 18, 2015 01:46 PM
