1993 t100 interchangeable rear end
Old Dec 4, 2009 | 05:41 PM
nyranger's Avatar
can you put a rear end of a different toyota in a 93 t100
Old Dec 4, 2009 | 05:47 PM
tc's Avatar
tc
Yep.
http://home.4x4wire.com/erik/diffs/
Old Dec 4, 2009 | 06:37 PM
nyranger's Avatar
thanks for the reply
Old Dec 4, 2009 | 06:57 PM
DeathCougar's Avatar
Originally Posted by tc
I don't see it TC.....I know for sure you cannot use a T100 diff in a 79-95 Truck/4Runner housing, but I was also pretty sure you could not use a standard 8" diff in the T100 housing either, as the bolt pattern is wrong.
I suppose he didn't specify which year though, taking a second reading (if so, he posted in the wrong section). Tacoma, Tundra, Sequoia, and T100 diffs are all the same size and will fit in a T100 housing.
Old Dec 5, 2009 | 08:24 AM
nyranger's Avatar
i jusy wanted to know what rear end would fit a 1993 t100. thanks
Old Dec 6, 2009 | 01:41 AM
Assuming you have the 93 t100 housing.....then 95+ Tacoma, 00+ tundra, 01+ Sequoia, and 93+ T100 will fit. Of course, be sure you verify ratio.
Old Dec 6, 2009 | 05:54 PM
nyranger's Avatar
thanks
Old Jan 13, 2010 | 05:06 PM
nyranger's Avatar
so can you take the whole axle and all. and swap instead of just the diff. would be easier if i could,
Old Jan 13, 2010 | 05:54 PM
the T100 axle is much wider than what you have now, as well as having spring perches in the wrong place. They are also known for cracked spring perches, a problem you likely don't want to have to deal with.
Old Jan 14, 2010 | 02:55 PM
nyranger's Avatar
that is what i have is a 1993 t100. just trying to find out if i could put the whole rear axle of another truck on mine. thanks
Old Jan 14, 2010 | 05:08 PM
Sorry, forgot to read the thread again.
Yes, you can just swap the entire assembly, as long as you verify ratio first. If the donor truck matches your trucks ratio, then its a super easy swap. Just unbolt the axle from the leaf springs and unhook the brakes, then swap-a-roo!
Old Jan 15, 2010 | 03:58 PM
nyranger's Avatar
thanks deathcougar. much appreciated.
Charecter1
Nov 6, 2023 10:08 AM
Colington
Mar 8, 2020 09:51 AM
Daneums
Aug 20, 2015 05:36 AM
hangtown88toy
Jul 10, 2015 02:33 PM
akaphilly
Jul 9, 2015 02:18 PM
