'99 or '00 LIMITED w/ Rear Diff Locker?
Just wondering, is there such a thing as a 1999 or 2000 Limited 4Runner w/ the Rear Diff Locker?
Or would all 99-00 Limiteds (with that button next to the dimmer) be for a center diff lock? I'm curious since I think that those years on Limiteds came w/ Multimode AWD--so maybe a button there is for the center diff lock?
It'd be great if someone can comment that actually has a 99-00 Limited w/ the Rear Diff Lock.
More precisely:
1999 4Runner Limited
- 2wd becomes AWD with push of button (located on the side of the transfer case shifter). Can be engaged for use at any speed and on dry pavement.
- full time selectable high or low 4wd by throwing transfer case shifter. Not for use on dry pavement. 4high can be engaged at speeds up to around 40 mph (pls confirm w owners manual). 4low engaged from stop.
- push button electric rear diff locker available when in full time 4low. Rear diff lock available only at very slow speed. See owners manual.
Cheers,
Bruce
Cheers,
Bruce
I am going for '99-'00 with locker and 5-speed, but the limiteds endless traction options seem pretty legit. The 5-speed does not come with the AWD correct?
BimmerSage
Sep 17, 2015 11:48 PM
Peevedkitten
11
Aug 31, 2015 06:57 PM
dropzone
Aug 11, 2015 05:16 PM
