EvLTwiN's CHOTA 1989 Build-Up Thread
Old Nov 23, 2009 | 07:37 PM
EvLTwiN's Avatar
This is my new project. I call it the CHOTA T-5. It began its life as this 1990 Chevy K-5, EvLTwiN's CHOTA 1989 Build-Up Thread-img00283.jpgand this 1989 Yota regular cab.EvLTwiN's CHOTA 1989 Build-Up Thread-img00282.jpg
Old Nov 23, 2009 | 08:24 PM
EvLTwiN's Avatar
Chota T-5
First we started by pulling off the front clip of the K-5 and moving all the wires to the top of the motor and away from the fire wall. Next we pulled the computer and the wiring harness from the cab and sat them aside. After we finished removing the rest of the interior we unbolted the body from the frame and cut it down so it was easier to handle amd removed it.
Old Nov 23, 2009 | 08:37 PM
EvLTwiN's Avatar
Next we removed the body from the Yota chassis and brought the body into the shop, we tore basically everything out of the engine well that wasnt important to function like the lights etc since we saved basically every wire out of the k-5.EvLTwiN's CHOTA 1989 Build-Up Thread-img00298.jpg we went ahead and pulled out the yota bench seat and the flooring since it was convenient. We also removed the yota brake booster and clutch pedal assembly and reservoir since the new tranny is auto. With everything removed we went ahead and did a little trimming, removing about 6" of the enginewell/fenderwell just to make sure there was enought room for the V-8. after some quick measuring we realized the radiator had to be relocated, so we pulled it off and sat it aside. and at 8:30 last night we decided to test fit the body. Like a glove!
more to come later this week, and some better pics too hopefully
Old Dec 8, 2009 | 06:03 AM
EvLTwiN's Avatar
Sunday we welded up the new body mounts. I decided to re-use the K-5 mounting plates and just build off those.
I used 3"x4" square tubing with a 3/16 wall for the vertical support and welded 1/2" plate to the top of that to connect to the Yota body.
With the mounts all welded up, my 6'3" and 250lb master welder, who we affectionately refer to as Pee Wee, welded the mounts to the K-5 frame.
We also added some gussets for a little extra support. here it is finished.
Just for stability for the moment we tac-welded the body to the mounts until i drill out the plates foir the bolt holes and secure it properly.
Old Dec 20, 2009 | 05:20 PM
EvLTwiN's Avatar
Today I drilled out the bolt holes in the body mount plates and bolted the body down. No pics. The mechanics of it are pretty simple. Drill hole, insert bolt with washer, add lock washer and nut on opposite end and tighten. Repeat. More to come. Stay tuned.
JHalcyonM
Mar 6, 2019 08:37 AM
89Yota4x4RatTruck
Aug 23, 2015 04:05 AM
corey519
Aug 12, 2015 11:12 AM
ghostmoney
Aug 6, 2015 08:40 AM
